Question about Zyxel P660HW-D1 Router
I am trying to set up the post office preconfigured Zyxel router, but the network found is called 'Setup' and I cannot change it, name field is greyed out - how can I fix this?
  • 25 Answers
Hi
plz double chk the enable ssid broadcast is not unchked under w/l setting of ur router settings
or
u can check the firmware of the router and if it is old u can try to upload the firmware from the zyxel website. then u can try to see r you able to change the name field or not
if not
try to reset and reconfigure the router if u can.
gud luck
thanx and regards
sukhiii
Posted on Jul 26, 2009
I need help putting a password on my wireless connection through my router. How do I do this?
1. Connect your internet to a computer
2. Go to internet browser -> type in http://192.168.1.1 in the address bar
3. You should see the router login page. Type in default user name and password
username : admin
password: 1234
4. Follow a setup wizard to put your device name and wifi password.
I have attached the manual link below:
ftp://ftp2.zyxel.com/NBG-416N/quick_start_guide/NBG-416N_1.pdf
hope this help.
Aug 06, 2014 | Zyxel Computers & Internet
How to change password for wifi
1 - Enter your router's address in a browser window. In the URL field, enter one of the following numbers based on the model of wireless router you use:
  • 192.168.2.1: Belkin, Microsoft, and SMC:
  • 192.168.0.1: Qwest (AKA CenturyLink), Netgear, DLink, Senao, Trendnet
  • 10.0.1.1: Apple
  • If you don't see your router listed here, search on Google for your router name and include "default IP address" to find the correct information.
  • On a PC, open the command prompt (click on Start > Run/Search for "cmd") and enter ipconfig. Look for the Default Gateway line, and try that number.
  • On a Macintosh, open Network (System Preferences..., Network) and look for Router:<number>. This is your router's IP address.
  • Enter your router's user name and password, if requested. Not all routers require that, but if yours does, it should be listed with the documentation. If your router does require a password, but you didn't set one, the default password is usually "admin." You can usually leave the username field blank.
Go to your settings page. It may be called "settings," or "wireless setup," "preferences," or similar name.
Locate the password setting. It may be a field or tab named "password," "wireless security," "security key," "passphrase," etc. If the field is directly editable, enter your new password. Otherwise, click the tab or button to access the password field.
Enter a new password. If there's a second password field, re-enter your password exactly the same way, capitalizations and all. If not, just enter the password once, but be sure to enter it carefully, and make note of it until you have it memorized.
  • When finished, click "OK," "Apply," "Submit," "Save," or whatever button finishes the process.
  • Close your browser window: your password is changed.
Feb 02, 2014 | Computers & Internet
Lynsksy E1200 tried to reset. my passord and network name are of no assistance. After running software, router is not found. Tried using "admin" for both but nothing works. Please advise. ...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Computers & Internet
I am trying to configure my new NBG4115 3G router connexion, but when I try to connect to the Zyxel setup screen via http://192.168.1.1 the Tilgin home screen appears. My present router here in our home is...
Either your web-browser has "cached" the web-page previously delivered by the TILGIN,
or your computer is still connected to the TILGIN.
In the former case, "reload" the web-page.
In the latter case, turn off the TILGIN router, and try again to connect to the ZYXEL router.
Also, check that your network-cables are correctly connected to one of the LAN ports on the ZYXEL router.
May 12, 2011 | Zyxel NBG-415N Router
I want to change the name and the security password from default..but how? can anybody help me? thanks..
You can change the wireless name (SSID) and the wireless password by accessing the setup page. To access the setup page, do the following;
Open internet explorer or firefox and type in 192.168.0.1. It will ask for username and password. In the username field, type "Admin" , A in Admin should be a big letter. In the password field , don't type anything. Hit enter in yout keyboard and you will see the set-up page. In the set-up, look at the right side and click Wireless Settings and you will see Wireless Network Name (Also called the SSID) , and change that. Under Wireless Security Mode, change the wireless password or Passphrase.
Nov 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How to change my zyxel p660 router name or id?
Point your browser to http://192.168.0.1.A page will appear with the router settings.Look for basic setup or wireless.If you get to then in the "wireless network name" change as desire and click save.
Nov 04, 2010 | Zyxel P660HW-D1 Router
Other routers taking over my router connection even when password
Its possible you have no authentication setup on your router. At the very least, please setup your router and all devices in your network to have WEP authentication. If your router and devices can handle it, please setup WAP or WAP2 authentication (instead of WEP). This should make your environment a lot more secure and prevent others from taking over your router.
Jan 02, 2010 | Zyxel NBG318S Kit Wireless Router
I cannot connect to wifi in my ipod touch
Change the router encryption or create an encryption as WEP using your Zyxel router.
The connection in your college is maybe unsecured or no security?
- Try also to check the settings of your router make that unsecured or configured a WEP encryption to the router.
- Turn off the MAC filtering of the router (Under advance settings)
- Disable the wifi-protected setup of the router (Under advance settings)
- Refresh the network list before reconnecting to the network.
Note: As we try WEP encryption to some of the router, the IPod can connect to the network.
Mar 08, 2009 | Zyxel P660HW-D1 Router
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
How do i make my network wireless?
1 - Connect your router to your modem.
2 - Connect your notebook to the router. This is temporary, until you get wi-fi set up in the router.
3 - Start up a web browser, and type in the address 192.168.1.1 - this will access the web setup interface of the unit. Leave the name field blank, and type "admin" for the password (you should change this, once you have it configured).
4 - Setup the internet, etc, and make sure it's working.
5 - Go into wi-fi settings, and create an SSID (essentially, this is what the unit will be called). It probably already says "linksys" in that field. Change it, then create a key (it's a password) for your wireless network.
6 - Save your settings, then disconnect your notebook from the router. Reboot the router.
7 - Make sure you have wi-fi activated on your notebook. Some do this automatically, some don't. It should "see" your network, with the name you gave it during setup. Click on it to connect, and you'll be prompted to enter the password you assigned during setup.
8 - Go surf wirelessly.
Cheers
Nov 04, 2008 | Linksys WRT300N Wireless Router
Zyxel P660HW-D1 Router Logo
448 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
