SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
SOURCE: Our HP Media center pc will not power on. I push
bad power supply. remove cover, remove power supply and it to best buy and get a new one. easy fix once ya take a look at it
