When I try to copy Outlook data from the DVD to HDD it is getting an error '' cannot copy Outlook: data error (cyclic redundancy check) kindly do the needful to resolve the issue. Thanks & Regards Abhiram
  • rsiddell May 11, 2010
    Are you trying to copy your personal folders/pst's, contacts, calendar items, etc? How are you attempting to copy your outlook data?
  • 25 Answers
CRC error indicates bad sectors, try one thing:
open the data file from outlook and from there create a new pst on the destination and copy the mails, you may loose some mails but the rest of the data will be safe
Posted on Aug 11, 2009
Data error. Cyclic redundancy check
https://www.openfiletool.com/pstopen.html
This application protects the privacy of user information and does not forward your personal data to some kind of external services for PST file analysis.
Regards
Oct 28, 2017 | The Computers & Internet
Data error cyclic redundancy check
This is some serious problem when u get it on HDD......is the data important? try formatting the hdd and use it....
Dec 29, 2013 | Transcend Computers & Internet
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
HI GOOD EVENING I AM UNABLE TO COPY MY MICROSOFT OUTLOOK 2007 PST FILE TO EXTERNAL HARD DISK. AFTER STARTING COPY FEW MINUTES LATER I FACE THE FOLLOWING PROBLUM CANNOT COPY OUTLOOK:DATA ERROR(CYCLIC...
A "CRC" (Cyclic Redundancy Check) is caused by an disk-drive error.
When you write a "block' of data to your disk-drive, a CRC value is calculated, and is also written to the disk. When you try to read that "block" of data, the CRC value is also read from the disk,
and a new CRC is calculated from the data. If the "new" CRC does not match the "old" CRC, then you have a "check" condition -- either the data was not written correctly, or the data could not be read correctly.
Now, did the "check" message refer to the "source" of the copying operation (namely your 'C:' drive) , or the "target"(namely the external drive) ???
Try to copy the PST file to another file on your 'C:' drive.
If you do not see the "check", then it is the external disk-drive that has a problem.
If you do see the "check", then open Outlook, create a new folder,
and copy a group of messages into the new folder. If Outlook reports that one of the messages could not be copied, then the disk-space occupied by that message is faulty, and must be excluded.
Sep 07, 2010 | Computers & Internet
I downloaded some videos to my hard drive. When I try to burn them on or erase them from my DVD, I get this error: "Error 0x80070017: Data error (cyclic redundancy check)". What should I do? Note: ...
Cyclic redundancy is one of the data checking algorithms and it is getting a non-recoverable error for some reason.
I suspect the software you are using to burn the DVD may be corrupt or incompatible with your Vista operating system.
It ALSO might be that the video is COPYRIGHTED and you are being blocked from copying it to a removable medium. There is no solution for that situation.
Feb 09, 2010 | Creative Labs (7300000000268) 20 GB Hard...
Cyclic redundancy error
In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear,
All of the above is true, didnt write it myself copied it from a good friends post. It is probably the data itself that is corrupted. Doesnt mean the data is gone. Try running a disk defrag, if that doesnt work try copying it to a cd/dvd and see if you get the same error. If you dont, flash your bios. This should explain your problem, if it doesnt follow up with me, email address is kustom42 at gmail.com.
Jul 14, 2009 | E-Machines eMachines Desktop PC
Data error cyclic redundancy check. I have windows XP.How do I fix this?
Your disc is scratched. That error will come up when it happens. Try to clean your disc. get all the fingerprints off of it.
May 24, 2009 | E-Machines eMachines Desktop PC
Unable to copy files from cd
Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
Thanks
Mar 01, 2009 | Computers & Internet
Cyclic Ewdundancy
cyclic redundancy means the actual data comosing the file has been corrupted. dvd shrink sometimes corrupts data when the compression is turned too high. CRC errors are problems in the base Hexidecimal coding used above binary coding that the proccessor uses.
Basically, you need to get new data cause that one is gone.
Jan 14, 2009 | Computers & Internet
It sounds as if the install software is corrupted.
Download a new copy and try again.
The Linksys download page is here.
http://www-uk.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=UK%2FLayout&cid=1129319214507&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1450714507L02
Hope this helps!
Matt
Feb 29, 2008 | Linksys WUSB300N Wireless Adapter
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
