Question about Intel Motherboard
Window instolation bootig files for hanging
Window instolation booting files for hanging
and restarted problam software working hanging
    President:
  • 1,383 Answers
Refix your RAM also check your hardisk is properly detected in bios .
Load optimal defaults settings in bios.
Aslo try with other bootable disk some times disk corruptation create this problem.
Posted on Jul 23, 2009
  • kishor
    kishor Jul 24, 2009
    Also check motherbord and RAM some times it has issue so try other mother bord and RAM.
    Please rate solution if it helps.
    Many
    Thanks.
My laptop will hang up at loading your personal settins
Laptop hang issues can be a frustrating issue for the user and a tedious problem for a technician.
The variety of causes for this event are staggering, but many can be diagnosed in a few simple steps.
Peripheral Issues
USB drives, inserted before boot, will cause a hang.
Remove all such devices and media (such as CDs and floppy disks) before booting your laptop.
Software Causes
Press "F8" at boot and press "Last Known Good Configuration" to take your laptop to a previous working boot. Starting your laptop in "Safe Mode" by pressing "F8" at boot will help
you check for software causes for a hanging laptop.
By turning off unnecessary processes, this mode allows you to run anti-spyware and antivirus software to clear malware that hinders performance.
Perform a check disk by right-clicking on your "C Drive" found in "My Computer."
At the "Properties" link, press the "Tools" tab to schedule error checking.
Reboot your laptop and let it perform this check.
Hardware Causes
Verify that your RAM is seated correctly by removing it carefully from under its access door on the bottom of your laptop and reinserting it.
Do not touch its gold contact points, as this may damage the memory.
Download the hard drive manufacturer's diagnostic software to test the integrity of the hard disk.
If you have access, run a professional hardware diagnostic suite to check the motherboard and CPU.
Boot with the battery removed to verify that there is not an issue with power conflicts.
Final Considerations
Checking the "Event Viewer from Administrative Tools" located in "Control Panel" (XP only) can also shed light on potential causes.
Performing a repair installation of Windows can address missing files, registry errors and corrupted system files without damaging your data.
This process requires your original Windows disks but is often quite useful.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
hope this helps
Oct 25, 2012 | Gateway Computers & Internet
My laptop desktop windows 7 always hang
Laptop Hanging Problems
Peripheral Issues
Software Causes
Hardware Causes
hope this helps
Oct 24, 2012 | Computers & Internet
My lenovo think pad hang frequently, some time it shows fan problem...please help me out..
Peripheral Issues
Software Causes
Hardware Causes
hope this helps
Oct 23, 2012 | Computers & Internet
I let the HP asst. Install a bios update and the install is stuck at 40%. What can I do to get out of the update?
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
Sep 29, 2012 | Computers & Internet
Nokia3110c restart problam & what solution
It is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
Dec 29, 2011 | Ace Hardware Home
My motherboard is asrock h55m-le it is showing some problem.. on starting windows.. my windows sign hangs on startup.. please advice me what to do.. i think it is over heating problem..
where your screen hangs....
1 if using XP did it hangs when xp is bootig??
or any other time.
and if yes then it is not mother board problem ...rather it is a hard disk problem.
you will have to zero fill your hard disk.\
if helped ..please thum up
Jan 09, 2011 | Asrock H55M-LE LGA1156/ Intel H55/ DDR3/...
My not start hang problam not start with seftly touch screen opt
Appears to be a software problem. Most startup probs are software related..If the phone boots up , but touch screen does not work , then is a board or lcd issue...
Apr 24, 2009 | Lands Phones
Windows mobile unable to see the screen
your phone is in bootloader mode (3 colors) and when you insert the usb cable you will see on your display USB down-left i remember.         http://www.4shared.com/file/92882688/6d8ff7d8/no_nonsense_4.html   here you have a new rom. just click rom updateutility and follow the steps. if your phone has reached Windows Mobile Logo Screen you must Hold Power + voice speed dial
Reset the device (do not release Power and voice speed dial)
After a few seconds you are in bootloader state.
Jan 07, 2009 | HTC P3300 Smartphone
I really need to recover files from my sandisk cruzer
Have you tried this? restart your computer and plug your USB in again(this helps to clean the buffer), see if you drive can be recognized.
If you still can't access the data inside, try this data recovery program Wondershare Data Recovery. Get the program here,
Windows Data Recovery (Windows Version)
Mac Data Recovery (Mac OS version)
Take care - Before those items are recovered, stop saving more files to the device in case the file data are overwritten!
Nov 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Intel Motherboard Logo
222 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
