Question about LG Washing Machines
My LG washer WF T652A has eror code PE. I have replaced press.sensor switch but still keeps alarm beeping and won't work. Last time this error code came up we replaced press switch and it fixed the problem. What is it this time?
  • 210 Answers
SOURCE: PE error code on LG WF-T653A
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
SOURCE: Warning alarm
i am using an LG washing machine model WF-N6861DN.its giving a warning alarm after 3-5 seconds of operation
Posted on Jun 21, 2009
SOURCE: loss of power on LG WF-T652A
I have the same problem as you. Machine was stopping intermittently in wash cycles - usually near spin/drain and sometimes just wouldn't turn on. Now it won't turn on at all...
Posted on Jan 17, 2010
techbuster
  • 5081 Answers
SOURCE: What does PE mean on my LG washing machine
Check the pressure switch -the system that determines correct water level in the drum. If its giving an incorrect indication to the program timer machine will either overfill, refuse to fill or refuse to spin. Its an air operated diaphragm switch triggered by rising air pressure induced by the entry of water into an airtight vessel attached to the base of the drum. It tells the program timer that the water has reached the correct level, allowing it to proceed to the water heating stage in the cycle.
Power off, drag machine out onto the floor, remove back cover and top cover. The pressure switch is a round item about 3 inches across with several wires and a thin rubber pipe attached. It generally sits just under the top cover. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage.
Switch itself may be faulty but its more likely the pressure pipe or the vessel attached to the other end of the pipe is blocked. Some machines have the pressure vessel integrated as part of the filter unit, with a pressure chamber moulded into the top of the filter body. Remove the pressure vessel, put a small nut or screw in it, fill it with water and shake vigorously till any crud or residue is removed. Refit all parts, check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction.
Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Power off, drag machine out onto the floor, remove back cover or tip machine up at an angle. Locate sump hose, remove the tensioner clip by squeezing the tabs together with a large pair of pliers or vise grips, remove the hose, take out filter and clean. Be prepared for spillage of water. May help if the machine is tilted backwards at an angle.
Posted on Mar 04, 2010
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
LG Fuzzy logic 6.5kg WF-T7519PV washing machine.Sensor panel error PE where E is flashing indication with sound.
This PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch. If no water is going into the machine, check the water inlet valve operation.
Apr 24, 2017 | LG Washing Machines
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Hi I have a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
PRESSURE SENSOR ERROR // Water level pressure switch error
The manufacturer has assigned this error or fault code to indicate that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Jul 04, 2016 | LG Washing Machines
I have a LG 3step Turbodrum Fuzzy Logic WF-T8018TP when I put on the auto/off button it keeps on showing me the error PE how can a fix this
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 14, 2015 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
LG model (WF-T1122TP) we are trying to wash all we getting PE what that means
Dec 07, 2014 | LG Washing Machines
LG wf-t652a displays an error "PE" & dinging when turned on. Any suggestions.
Pressure sensor error. Check also the pressure hose. The pressure sensor stops the water at a set level depending on the cycle you choose.
Jul 16, 2014 | Washing Machines
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
"PE errors lg washer wm2032hw" I replaced the
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
Sep 03, 2013 | LG WM-2032H Front Load Washer
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
Washing Machines Logo
90 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
