Question about RCA Universal Remote Control
Remote such automaticaly
I have a problem with philips remote which is suching automaticaly i mean is changing the chanel in the Philips tv without stoping
    Novelist:
  • 133 Answers
Looks like a jammed "channel up" (P+ , CH+ or similar) button on your remote. Try disassembling the remote and cleaning the rubber pads with some ethyl alcohol and cottonwool. Also clean the pads on the circuit board which come in contact with the buttons pressed.
If your TV set has channel up/down buttons on the front panel, it could be that one of these is jammed instead (could also be something else, i just suggested the most likely solution i could think of).
I hope this helps somehow...
regards
3rq8 (Triarcuate)
Posted on Jul 24, 2009
I have a Philips tv model 42FD9954/69c but it doesn't have a remote so I cant turn it on how do you get it to work with a universal remote ?!
Most TVs have controls on the side of the TV to operate power, volume and channels, if the power button puts it to standby then use the Chanel up or down to turn it on! Depending on the universal remote being used just select the code relevant to the make of TV you are connecting to!
Nov 01, 2014 | Televison & Video
Philips 21pt1654 58
Hi, are you sitting on the remote? does the TV have analogue/manual control buttons on itself, are they jammed in or damaged in any way? Are any of the buttons on the remote damaged in any way?
To rule out the remote, remove the batteries, if the problem still occurs it's the TVs problem, if it doesn't it's the remote.
Mar 21, 2014 | Televison & Video
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
Tv philips 29'' 29PT 9416/12 the time that the tv is on automaticaly alone stop. Then i turn on tv and it works.
You may have "sleep timer" set up. Try selecting "Timer" on your remote control to see if the "sleep timer" set. if so make it "0".
Nov 24, 2009 | Philips Televison & Video
How can i access the menu to adjust picture without the remote
On front of TV Press and hold vol- and vol+ together menu should apear then.
Jun 11, 2009 | Philips 60PP9202 60" Rear Projection...
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
Help
you'll need to bring up the menu, under "channels" or "set-up" you will find something called autotune (or manual channel set-up). it will automatically set the channels you pick up.
May 28, 2008 | Philips Magnavox 20MC4304 20 in....
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Model MW C20T6 Serial # V08613170
the Magnavox TV codes for a phillips universal remote are:
MAGNAVOX 0807, 0002, 0502, 0247, 0919, 0224, 0430, 0402, 0408, 0109, 0715
Nov 18, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
137 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
