Question about Motorola Mobility i880 Cellular Phone
Debroke in half need to turn transmitters back
Broke in half need to turn transmitters back on
    Problem Solver:
  • 17 Answers
Press menu, down down, up, ok, up up, ok, then press ok again to turn them on that will work if its on high contrast if it is on one of the others press press menu, right right, up, ok, up up, ok, then press ok again to turn them on. Hope this helps!
Posted on Jul 26, 2009
Expedition won't unlock Transmitter works but the
Try unlocking the door lock using the ignition key
Oct 19, 2013 | 2000 Ford Expedition
Where can i buy just the outside temperature transmitter, mine fell and broke
have you found a replacement? Mine stopped working and I need a new one too,
Feb 07, 2013 | SkyScan 86709 Atomic Wall Clock
Is it possible to just get a new remote and not the whole kit?
You can certainly try putting it back together to see if it works.
If it is not fixable, you should be able to purchase just the transmitter to your fireplace remote control.
Please reply with your remote control's model # (typically found on the back) and I can help you find the appropriate transmitter.
Dec 27, 2012 | Empire Comfort Systems Empire...
How do I change the battery in the key fob and do i need to reprogram it afterward?
Hell, and welocme to FixYa!
The remote comes apart, the front half detatchs from the back half, a small screwdriver is all you need.
The battery is easily removed once the case of the fob is open.
There is no need for any reprogramming once the battery is changed; the computer remembers the frequency of the transmitter.
Mar 04, 2010 | 1999 Toyota RAV4
I broke my transmitter. What can I do?
Hello
it is not worth the effort, go a buy a mouse, its going to cost you around 10 for a basic wire mouse. the time and effort to make your old one wired, its not worth it.
Jan 08, 2010 | Logitech Labtec Wireless Laser Mouse
How to program a keyless remote for a Pontiac
NOTE: You must have the correct part number on the remote for it to work. The part number you need is 15732803.
Transmitter programming per the GM manual:
Before entering the programming mode, verify the possession of all the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases the other transmitters. You may program up to 4 transmitters.
  1. Turn OFF the ignition switch
  2. Usa a fused jumper (3 amp is sufficient) and connect terminal 8 (back/white wire) to terminal 4 (black wire)
  3. Close all the doors
  4. Turn ON the ignition switch / the doors will lock
  5. Press and hold the following buttons on one of the transmitters for 30 seconds: lock and unlock
  6. After a 30 second delay, the doors will lock and unlock Important:
    DO NOT turn OFF the ignition . If the switch is turned OFF the first transmitter becomes inoperative.
  7. In order to program extra transmitters repeat Step 5
  8. Disconnect the fused jumper wire from the data link connector
  9.  Turn off ignition
  10. Verify functions of all programmed transmitters.
This should work for the 1997 and 1999 Bonneville's. Good Luck. Keep me posted, be glad to answerer any other questions you may have.
Aug 11, 2009 | 1997 Pontiac Bonneville
99 expedition trans feels like it engages but will not move.fluid level is ok
Check out these things: rear wheels locked up because of emergency brakes coming apart inside rear drum/rotor.
Rear axle broke
4x4 controls switched half on-half off.
Torque converter broke
All of these problems will not make much in the way of noise. You will need both rear wheels off ground and trans in neutral to turn the rear wheels. If they turn its likely the torque converter.
Aug 06, 2009 | 1999 Ford Expedition
How to replace a cv joint on a 2005 toyota corolla, i cant get the cv joint back part off the transmittion. driver side cv joint broke and rear part is stuck to transmittion..
There are two types of cv joints used. One type bolts on the other you have to pop out. Do this by prying it out with a big screwdriver. A c-clip hods it in and it will pop out for you. When reinstalling be sure it seats back in.
Jul 26, 2009 | Toyota Corolla Cars & Trucks
Phone broke in half
that is going to be so hard, try your mobile provider
Nov 24, 2008 | Motorola Mobility RAZR V3
WIRE FROM RECIEVER BROKE
what kids wire reg wire re strip it tie it back toghter tape it up once
Oct 07, 2008 | RCA WSP155 Main / Stereo Speaker
Motorola Mobility i880 Cellular Phone Logo
69 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
