Question about Car Audio & Video
I want to run a new connection from the battery to my car radio how do i do that what must be connected to the positive and negative on the battery and what colors do i connect it to on the deck i have black ''ground'' then red and yellow and blue as a antenna
    Sergeant:
  • 273 Answers
Ground to neg bat termial or metal on chassis red and yellow should be live and ignition so both to pos bypassing the need for wiring to ignition stem don't worry about blue unless you have power antenna and want it to work
Posted on Jul 23, 2009
HOW DO I WIRE A 2ND BATTERY ON MY TRANSIT CUSTON 2014
123Mitch eazy ,its called wiring battery in PARALLEL that means positive to positive and negative to negative ,run new wire from old battery to new battery positive, now run a new wire from old battery to new battery negative, that's it. NEVER cross neg to pos. if this helped you please let me know ,good luck .
Woody
Sep 15, 2014 | Ford Transit Cars & Trucks
How to change the battery on a Hyundai Sonata
When you remove the battery to install a new one then you need to enter a radio code to get your radio working again. This is an anti-theft locking system.
To avoid reprogramming your car/radio etc. connect another battery with jumper lead to the battery leads on your car to maintain your car's settings when you disconnect the old battery from your car.
Install the new battery and connect the car's battery leads to the new battery. now you can remove the jumper leads and the second battery.
WHEN YOU CONNECT THE JUMPER LEADS, MAKE SURE YOU CONNECT POSITIVE TO POSITIVE AND NEGATIVE TO NEGATIVE.ON BOTH BATTERIES.
Oct 19, 2012 | Hyundai 2006 Sonata GLS V6
2004 sunfire ignition key wire does it have one/ instaling new radio only have constanyt 12 volt radio power on off button does not shut off do i use this wire and where does it go the ignition wire...
Hi, your factory Sunfire wire colors are pasted below. The yellow wire should be accessory. This should connect to the stereo's red power wire. The orange "always hot" wire should connect to the stereo yellow wire--this is only used to keep your station presets in memory. Please let me know if you have more questions, and thanks for using FixYa.
2004 Pontiac Sunfire Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 04, 2011 | 2004 Pontiac Sunfire
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
How do i install it it was a hand me down with no instructions
http://dl.owneriq.net/a/a44b260d-f7bb-4ae7-bd9f-5a4722cb9427.pdf
in general
the positive terminal is connected to the positive of the battery
the negative terminal is connected to a metal grounding point on the car ( find a metal spot on the car to connect the negative terminal of amplifier)(do not connect it to the negative side of the battery)
the remote terminal connects to either the remote line from the back of the radio blue and white wire
if the radio does not have a remote wire then use the red wire which is the acc (check this against your car wiring)
the speakers are simple connect the positive of radio to positive terminal ect
and the input comes from the radio as a phono jack connect that to the input of the input of the amplifier right left ect ect also if the radio has only left and right then you need a splitter for the phono cable because your amp is 4 channel
if the radio does not have phono jacks then you need to take the output that usually goes to the speakers and route them to the amp and attach pho no jacks on them
Jan 10, 2010 | Alpine MRV-F357 Car Audio Amplifier
Speaker wiring
Here' s the colors to look for in the dash:
1994 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Light Green/Yellow
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
Jun 03, 2009 | 1994 Ford Probe
What wires do i connect for my cd player? What colors connect?
here are the factory wire colors and what they do.
1999 Ford Escort
Radio Stereo Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Under the driver seat.
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Mar 04, 2009 | 1999 Ford Escort
Radio installation in a golf cart
Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
Jul 22, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
How do I change the battery on a 1999 volkswagon beetle?
Open the battery compartment. Loosen the bolt on the negative battery post first. Then remove the negative cable from the battery. Do the same to the positive cable. Remove the hold down bracket with a 10mm wrench. Lift out the battery please keep in mind it has acid in it. Now replace with new battery and connect the cables negative to negative , and positive to positive. You may need to reset your radio stations on your car.
Jul 09, 2008 | 1999 Volkswagen Beetle
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
