Can anyone help me with overclocking. i have a mb asrock k7s8xe chipset 748 bios P2.20 cpu barton athlon xp 3200 2 x 1gb 333 ddr.os vista enterprise. i am trying to increase the cpu to 2.4 ghz using only a fan cooler so my son can play the new sims 3.
    Master:
  • 404 Answers
Lol, wont make a diffrence, more hassle and not worth overclocking.
Posted on Jul 23, 2009
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
Memory ram
According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Jul 22, 2009 | Computers & Internet
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
Pc keeps rebooting
Try re-installing the operating system. It is possible it possible OS is not installed properly. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Computers & Internet
I have upgraded my k7s8xe with athlon xp 3200 cpu. I have adjusted the jumpers to fsb 200 & installed 1gb ddr 400 ram. system keeps rebooting os vista enterprise. any suggestions. also can i install 2...
First of all, if your FSB is set to 200mhz, the system will not support DDR400. "CPU at FSB 200MHz mode, it will NOT support DDR400". The FSB will have to be either 333 or 400mhz in order to utilize DDR400. Only 1GB of DDR400 is supported. As to your rebooting issue, could be because of these incompatibilities and/or you did not properly seat the heatsink/fan on the new CPU, which also means you might not have properly applied thermal compound or might have no applied it at all. All the compatibility information for this motherboard can be found at: http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Beeps beeps beeps everwhere on my desktop
Depends on the BIOS. The beep code means ether the memory or CPU. Since you are attempting to install a another CPU its probably a problem with the CPU itself (dameged or incompatible) or a BIOS setting problem. Also make sure you always use thermal paste. The replacement CPU might be heating up and not functioning.
May 26, 2009 | Asrock K7S8XE Motherboard
ASRock K7S41GX Motherboard
Page 7 of the user manual shows you which jumper to change in order to change the FSB; http://download.asrock.com/manual/K7S41GX.pdf
Sep 27, 2008 | Asrock Computers & Internet
I have AMD Athlon XP 2200+ m7vit bravo m-b
All current 333 MHz capable Socket A chipsets (VIA KT333, KT400, nVIDIA nForce2, SiS 746FX) should be compatible with Barton based processors although you may need to flash the BIOS for the processor to recognized properly
your board has a 333mhz front side bus so should be capable of running them
You must ensure that the cpu is for 333 mhz and not more and that it fits socket A which your board is
Please post rating thanks
Aug 01, 2008 | Biostar M7VIT Pro KT400 ATX Motherboard
CPU Upgrade
Athlon XP 3000+ is 400mhz FSB according to the link(http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_1274_3734^11672,00.html), means that in order to display the actual speed of your Athlon XP 3000+ you have to set your board 166mhz to 200mhz jumper setting or in CMOS utility overclocking option. and also just to inform you that your motherboard is in Overclocked condition when set, because it only supports processors up to 333mhz FSB (http://www.digital-daily.com/motherboard/soltek-sl75frv/)
Sep 11, 2007 | Soltek SL-75FRV Motherboard
Computers & Internet Logo
David Payne
David Payne
