Question about Whirlpool GS475LEKS Gas Kitchen Range
Whirpool oven! The burner in my oven goes out, but the gas continues to flow. The plot lights stays on.What do you think is the problem?
Putting the door back om
Posted on Nov 22, 2007
  • 139 Answers
The flame faliure device is faulty and needs replacing Thats why the gas goes out.. most people commonly call it a thermostat. 100% its that...
Posted on Nov 21, 2007
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Oven burner won't stay lit
Often it is is easy is getting a welding tip cleaner or ven the end of a paperclip in a size that matches the holes on your gas burner. Simply gently push and pull the welding tip cleaner paper clip or even wire in any of the holes that appear blocked. I had the same problem with my burners. I found a paperclip that matched exactly the size of the holes on my burners I simply push the clip into the holes to clear them. Runs like new now.
Dec 26, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Why won't burners stay on
Alguien puede ayudarme con el diagrama electrico del horno imperial
gracias
Jun 20, 2013 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Main oven dont light there is no gas coming through
Check the main oven burner and look for a small thin bar that goes across the burner on the left or right hand side, push it down and across into its seating. its part of a sensing device for the gas flow
Nov 27, 2011 | Stoves 600SiDOm Gas Kitchen Range
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
BURNER IGNITION WILL NOT TURN OFF. When turning stove top on, all 4 burner ignitions continue to stay on. They will not stop clicking. Only when I unplug the oven will they turn off. It is a Frigidaire...
One of the switches is stuck,causing circuit to 'think' that you're trying to light a burner. Give each control knob a good 'tap' with the back of a screw driver.If that doesn't free it up, we will have to find the stuck
switch
Jul 25, 2009 | Frigidaire FGB24S5A Gas Single Oven
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Whirlpool GS475LEKS Gas Kitchen Range Logo
140 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
