Slow reaction to mouse movements and image on screen no longer moves smoothly but moves in steps.
  • 2 more comments
  • Joe Barna Jul 23, 2009
    Nothing moves smoothly,everything jumps.
    Please inform how to increase buffer paging capacity.
  • Joe Barna Jul 25, 2009
    What happens on my screen now:is like watching a video where half of the frames are dropped.Nothing moves smoothly like before and the reaction time is very slow.
    There is no more smooth flow on my screen.Everything in every direction moves in steps and slowly and the whole system is much slower than ever before.
  • 1,555 Answers
Press ctrl plus alt plus delete go to performance and tell me what is your cpu usage and pf usage and let me know that have you increased your paging memory or not.
Posted on Jul 25, 2009
  • 6,487 Answers
If this was working fine before, just do first a system restore on the date and time when everything was working fine and that should correct everything here...To do system restore follow this
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
Posted on Jul 23, 2009
    Brigadier General:
  • 3,513 Answers
Thank You for contacting Fixya.com
In order to Enhance Mouse Precision Please follow the bellow mentioned steps as follows:
Slow reaction to mouse movements - 5836d1218758457-little-slow-reaction-mouse-movement-pointer-precision.png
To get there, it depends on your system. If you are using the Classic Control Panel then go to Control Panel --> Mouse --> Pointer Options tab and check the box.
If you are using the new Control Panel, then open Control Panel --> Hardware and Sound (you might can skip this step - 3 links under Hardware and Sound on my machine is Mouse) --> Mouse --> Pointer Options tab and check the box.
About the image moving slowly across the page I would suggest to increase the buffer paging capacity once you have done the above steps.
Good Luck and God Bless.
My cordless mouse is very slow
When you say 'very slow', I'm assuming it is slow to respond to movement. Does the mouse pointer behave this way if you use a wired mouse? If so, your problem is something in your operating system. If not, you may need to move the transceiver closer to where you use your mouse, or perhaps put it in a line-of-sight with the mouse.
Jun 11, 2013 | Computers & Internet
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
MOUSE SCROLL HELP
Check that you are not using this on a shiny or smooth surface. i am assuming this is a laser mouse and not a ball type. These types prefer surfaces that are different, like top of a desk where this wood grain. This is how the mouse knows how far it has moved by comparing one part of the surface to another.
Jul 16, 2010 | Computers & Internet
My mouse does not works properly/ it works slow, cursor makes little jumps, movement not smooth. Laptop samsung R40
Are you using it on a mousepad? If not, that is probably why you are getting jumpy and erratic movement. Put a mousepad underneath the mouse and you should see the cursor movement improve.
You can also adjust the mouse properties such as speed and control by going into the Control Panel and opening the Mouse applet.
Do you have the correct Dynex driver installed? If not, go to the Dynex website and download the driver for your mouse. Having the wrong driver (or a generic driver) can make a difference in performance sometimes.
Hope one (or all) of those solutions helps!
Jul 08, 2010 | Dynex Wireless Optical Laptop Mouse...
Jerky mouse
Try using a different Mouse Pad or surface. This is a cause of jerky and erratic mouse movement.
Hope this is of some help. Bud
Oct 07, 2008 | Logitech Cordless Mouse
Wireless mouse
sometimes wireless mouse is a bit slow in responding.
use a mouse pad sometimes it helps.
Mar 26, 2008 | Logitech Cordless Mouse
Slow Reaction
Since you've already check the properties, try replacing the batteries.
or make sure your mouse and receiver are within reasonable distance.
Thats all I can think off right now.
Good luck.
Mar 11, 2008 | HP Wireless Optical Mouse
Slow booting process, "twitchy" mouse movement
Do you have an anti-spyware program on your machine? There are many free programs out there. This might speed up your machine a bit.
Nov 07, 2007 | IBM ThinkPad R52 Notebook
Computers & Internet Logo
David Payne
David Payne
