Trying to install a logitech rj45 network adapter (ethernet card). I have xp. BUT (a) the computer does not list it under network adapters (i already have one which i think is integrated on the motherboard but whenever i plugged in the computer shut down, hence installing a separate pci card is a workaround) so i cannot install the driver from the disk; should be plug-and-play but seems not to be and (b) now my computer will not boot, shuts down after 10 secs. Hey-llp pls!
  • 2 more comments
  • justin_roake Jul 23, 2009
    Thanks for this. I have disabled the existing Network Adapter via the device manager, and it shows with a red cross through it. however the pci card does not also show. The reason i am doing this is that the exiswting ethernet adapter may be faulty, as when i insert the cable the pc simply promptly switches off.
    i cannot install drivers, as the pc does not see the card. also the setup.exe file does not appear on the driver cd (perhaps because the pc cannot see the card???)
    Also, it is a new hard drive, with a brand new install of xp on it, no other programs. therefore a hardware problem.
    Thanks for this, but it IS a brand-new network card.
  • justin_roake Jul 24, 2009
    Thanks for your help. But i have fixed the problem in a low-tech way - i simply took the new card out and installed in another pci slot. and when i booted up xp automatically installed it, and it works! both cards now show under network adapters, one with the cross through it to show it is disabled. thanks to all for your assistance.
  • 615 Answers
Dear sir,
Welcome to once again Fixya support
According your problem it seems to be your try to install faulty Network card. So better is check with new good card.another possibility is some time pci slots fail to recognise a hardware, so try it with another pci slots of mother board.According to you onboard network card is dead, means motherboard fails to work when connect to a network,after successfull installation of network card also the possibility of motheboard not allow you to work with new network card ,same situation may arise,i am also managed same problems in several customer place while working as an computer hardware engineer.So try with new network card it may solve your problem
good luck
Posted on Jul 23, 2009
  • 32,281 Answers
Why did you decide not to use the on-board network card?
Did you disable the on-board network card in the BIOS before installing the Logitech network card? The computer may not like two network cards installed.
Did you get the Logitech network driver and did it install properly, if not what was the error message?
To get to computer working again, press F8 as you bootup and then select Last Known Good Configuration, if this doesn't work then bootup again, press F8 and select Safe Mode.
Then go to Restore and select a Restore Point date prior to when the problems occured and before you installed the network driver.
If the on-board network works, I would suggest that you use this instead on installing the Logitech network card.
  • Chris Hingee
    Chris Hingee Jul 24, 2009
    When you get a red X through the network LAN connection when it was previously working, it may not mean the LAN card is faulty. The problem could be that the network card did not get an IP address from the router. To fix this problem, right click on the on the LAN connection and click Repair (this can also be done via the Control Panel - Network Connections), the network card will then get a new IP address from the router.
    If this doesn't work power down the router for 1 min. and power it up again, wait till all the LEDs are on before you boot up the computer.
    If this doesn't work, test the network by opening a DOS Window (Start - Run and type cmd and press Enter) then type
    ipconfig, if you get zeros IPs in the Ethernet adapter then you either have a faulty network cable or a faulty router.
    Sergeant:
  • 338 Answers
Hey , trying to set up an internet connection?
you may need:
- a blank cd-r or usb-stick for data-storage/transport
- support software for the mother board and it's on-board devices for win-xp
- win-xp service pack 3 CD ( download cd-version at microsoft's hp, burn it at someone else's computer
- a the driver's for the ethernet card(logitech homepage)
then try this:
activate the on-board ethernet adaptor in the bios, get support software from the mainboards manufacturers homepage suitable for win-xp
(hope your motherboard isn't too old)
install the software(might include also maniboard and pci-device drivers, just for internal handling)
and try checking for hardware changes in win-xp (hope you got win xp - professional)
if that does not work:
deactivate onboard-ethernetcard
put in the pci-device
bott up, install the proper drivers, gotcha
  • Andrej.cet Jul 23, 2009
    hey , trying to set up an internet connection?
    you may need:
    then try this:
I have a sony vaio laptop do i need a wireless card.
Almost all laptops being manufactured even 10 years ago has built it wireless card. I believe yours have built in one and no need to buy an external wireless card.
To further verify if you have it installed, you can check in in the Device Manager under Network adapters (if the wireless card driver is installed). To bring this up, follow the steps below.
For Windows XP:
Start -> Run -> devmgmt.msc (Type in the box) -> Expand "Network adapters" (You should see wireless and ethernet adapters listed)
For Windows Vista and 7
Start -> devmgmt.msc (Type in the start search box) -> Expand "Network adapters" (You should see wireless and ethernet adapters listed)
If you want to further check if you really have the wireless card installed, please post the make and model of your laptop.
Hope this helps.
Jun 26, 2011 | Sony Computers & Internet
How do i know if i already have an ethernet card
From Control Panel, goto the Device Manager
Find Network Adapters in the list
Click on it. if you have ethernet card/network adapter it will be listed there.
Hope this helps.
May 12, 2010 | Dell Ethernet Card Network Adapter
Install ethernet card optiplex gx260
That slot is actuall not accessable externaly. The open bay is for the AGP slot right next to it. Directly to the left of that slot you have a riser board the provides 2 additional horzontally mounted pci slots. You'll have to use one of these.
May 11, 2009 | Dell Ethernet Card Network Adapter
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
Wireless network card
In Vista, click on Start, right click on Computer, go to properties, go to Device Manager, look for Network Adapters and click on the + sign.
In XP, click on Start, right click on My Computer, go to properties, click on the Hardware tab, go to Device manager, look for Network adapters and click on the + sign.
If there is only on item listed under Network adapters then it is most likely the Ethernet jack, if there are two then chances are the second one is the wireless. It should say "wireless" somewhere in the name, if you have one. If it doesn't, then you've got two "wired" connections.
Apr 07, 2009 | HP Computers & Internet
The network adapter in a dell dimension PC running XP home
Ethernet controllers click here
Check for drivers on that site, however much better that you know the brand of your LAN adapter.
Mar 15, 2009 | Dell Dimension 8250 PC Desktop
Network Adapter/Ethernet Controller
Nothing wrong with having two network adapters installed on your computer. If you have this DWA-552 wireless adapter installed as well as an onboard NIC, the correct thing to do is have both drivers installed so you see them both in your Control Panel->Network Connections window.
If you really want the onboard nic to go away, go into device manager and disable it - not uninstall it.
Mar 08, 2009 | Computers & Internet
After re-installing Windows XP, the plug and play modem is not listed as part of the hardware? Hence, cannot connect internet?
You must install the driver software if it in not listed in --- go to "My computer" >> "Properties" >>"Hardware" >> "Device Manager" >> "Modems"  make sure that modem is visible in the list if so , insure that it is not showing with a red icon... if it is ... then install the driver from the modem driver CD....
Jan 03, 2009 | Computers & Internet
About ethernet
If you computer has already a ethernet card installed on it, just need to get a ethernet cable and connect it to your modem and the other to the computer and make sure the USB is disconnected already, then power off your modem and restart the computer then power the modem back on and check if internet is already working, if its not working you may need to contact your ISP and tell them to enable the ethernet connection of your modem....
Sep 14, 2008 | SMC Abocom ExpressCard to Ethernet Network...
About laptop ethernet...
First figure out whether your hardware is ok and driver is installed properly. In Windows XP, click Start , right-click My Computer , and select Properties .
  1. In Windows 98 and Me, right-click My Computer , and select Properties .
  2. In Windows XP, click the Hardware tab, and then the Device Manager button. In Windows 98 and Me, click the Device Manager tab.
  3. If the Network adapters category is present with a (+) sign , then skip to Step 6. If Network Adapters has a (-) sign , continue to Step 5. Disregard adapters that do not reference an Ethernet Adapter .
  4. If a network adapter is not listed inside, do one of the following items based on the condition of the networking hardware:
    • Networking hardware is not installed. Install a new network card (desktop computer) or a new network PCMCIA card (notebook computer) per the card manufacturers' suggestions. This does not apply to on-board networking hardware.
    • The network card is not seated fully into its socket. For Desktops, remove the side-case, reseat the network card, and replace side case. For notebook computers, remove and reseat the network PCMCIA card. This does not apply to on-board networking hardware.
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play network card is probably a better option.
    • For desktop PCs with on-board networking hardware, reset the BIOS:
      1. Restart the PC.
      2. Press F1 repeatedly when the first screens appear.
      3. Press F5 and Enter to reset the BIOS to default settings.
      4. Press F10 and Enter to save the settings and exit BIOS setup .
      5. Restart the PC.
      6. Check Device Manager again for the presence of the Networks adapters category. If the network adapter name is still missing, the on-board network adapter may be damaged. The motherboard should be replaced, or a PCI network adapter should be installed.
  5. If the network adapter is listed, but has a yellow exclamation mark over its icon c00060708.jpg , do one of the following:
    • Software drivers and supportive files may be missing or corrupted. Remove the device from Device Manager and reinstall the software by restarting the computer. See Step 5: Reinstalling network adapter software drivers .
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play card is probably a better option.
  6. If the network adapter listed has a green adapter icon c00060709.jpg , the networking adapter is probably functioning correctly. If the PC still cannot connect to the Internet, make sure to complete the following steps before continuing:
    • The cable or DSL hardware may have stopped responding. Reset the cable or DSL hardware using the manufacturer suggestions.
    • There still may be a connection problem. Recheck the cable connections and replace any cables that have been pinched or that you suspect are bad.
    • The Internet Service may be down at your provider. Most Service Providers have a telephone support number. Call the ISP support number. If an outage is occurring, an automated response about system wide service outages will probably play. In this case wait until the service comes back.
    If the network adapter icon is listed without problems, and the connections, service, and modem are working properly, then refresh the networking drivers.
Thanks
Iqbal
Mar 16, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
315 people viewed this question
David Payne
David Payne
