Question about Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer When pulling out a load of dry clothes a washer was sitting on top of the lint trap. The next time I dried clothes it made a thumping noise. What's the problem??!!Thanks!
  • 126 Answers
Sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Posted on Nov 22, 2007
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer is not heating up to dry the clothes
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer is taking over an hour to dry a load
Check the exhaust vent out back of dryer to see if exhaust pipe going outside is crimped or blocked. Let me know if air flow is better if pipe is pulled off back of dryer. Thanks, Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Dryer
forget dryer ck vent to outside look for kinked or flatened hose behind dryer find out side vent hood and ck air flow to verify vent problem try drying load without hose connected to dryer may get warm and a little dusty in room but worth it to verify fix
May 02, 2008 | GE WSM2420T Top Load Stacked Washer /...
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
113 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
