Hi Stefan:
I would not even consider trying to run the engine without coolant.
Diesel engines run hot and the engine will be ruined if run without coolant.
You have multiple start times in 1 or all of the programs A,B,C or D. 1 start time in the A program will run the zones in this program once on the days it is schedule to water. Example: Think of each program as a separate timer. All want to know 3 things What time to water, how long to water for and what days to water. Timer 1 is the A program. Set to water everyday at 8 am for every zone which has a duration. Don't want the plants to water everyday take the minutes out of zone run time in this timer or the A program. Want the plants to water M,W,F add a start time, a run time to corresponding zone and M,W,F in timer 2 or B program. Want the plants to water twice in a 24 hr period add a second start time to each timer or program. and so on. The programs are only used for watering schedules with more or less days per week you want a specific zone to water. Otherwise use only the A program with 1 start time for once a day or whatever days you desire for all zones.
When I start a new cycle, I first hear the pump run to empty out all
remaining water, and after that I hear the motor run for the regular
washing cycle, but there is no water in the dishwasher. After a few
minutes, the cycle stops, and the washer claims the dishes are 'clean'.
When I try starting a new cycle over and over again, about one in 20
times, the cycle will run normally with water. But then the next time,
the problem starts all over again. Once a cycle starts correctly,
everything works fine, including the rinsing.
The overheating is caused by the sludge. It is very easy to correct this problem. Remove the radiator cap and open the drain valve at the bottom of radiator. If possible, remove the reservoir and flush out with water. Make sure to get all sludge out of reservoir, then reinstall. Once the radiator stops draining, insert water hose (without nozzle) and turn water on. Keep the drain valve open. Run water through radiator until it runs clear. Once it runs clear, start the engine and let it run while keeping the water running through radiator. Allow engine to run until the thermostat opens up. Continue running water through radiator with engine running until the water from drain runs clear. Once you have done that, turn off the engine. Close the drain valve and refill radiator with proper mixture of coolant and water. Once radiator is filled, start engine and let circulate through engine. Coolant level will drop as the coolant starts circulating. Shut off engine and top off radiator. Fill the reservoir with the required amount of coolant. Testing the coolant at least once a year will help prevent this from happening again. Coolant should be replace a minimum of five years, less if coolant bottle specifies.
If it fills with water and starts the cycle and
the water keeps running in then your water inlet valve on the back where the
water supply comes in is sticking. It needs replacing. If it doesn't start the cycle:
Your pressure switch stops the
water and allows it to start the next cycle. It's a switch either in the
control panel or at the top of the tub with a small tube connected to it which
goes down between the inner and outer tube. As the water level increases the
air in the tube is compressed until there is enough pressure to make the switch
stopping the water from filling. This tube can get clogged and the switch won't
work. Remove the tube and clean it out. Blowing on the tube when it's still
connected to the switch will make the switch if it's working and clear.
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
if you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
