Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Remote Problem The enter key & up and left arrows have stopped working on the remote. All the other buttons appear to be fine
  • 13 Answers
Re: Remote Problem
Try removing the batteries overnight to see if that resets the remote control. Other than that it's either a warranty call, or if you feel really brave, taking it to bits to see if the electrical contacts on the pad need cleaning.
Posted on Dec 30, 2007
0 characters
3 Points
How to change region code in philips dvd dvp3858-94 model
From L Jefferson in a prior Fixya answer:
"remote control :
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu."
May 27, 2015 | Philips DVD & Blu-Ray Players
Lg dp132 check region code
1.Switch on the DVD player without any Disc inside
2.The screen should display 'no disc'
3.Eject to open the DVD tray
4.While the tray is open, press the 'STOP' button then hold the 'ENTER' button for 5 seconds
5. A new screen will appear (Regional Management Test Code) which will allow you to change the region code using the up and down arrow keys on the remote control.
6. Change the code to '0' and press the PAUSE key to exit
Dec 30, 2013 | LG DVD & Blu-Ray Players
How to make my philips DVP3747 region free
Here is a hack that I've found to work on many Philips machines.
Turn on Player
Using Remote Control open the Disk Tray (and leave open)
Using Remote Control Press SetUp
Using Remote Control Scroll To Preference using Left / Right Arrow keys (Just Highlight it do NOT select it)
Using Remote Control Press 1 3 8 9 3 1
Region Menu Screen Should Appear
Using Remote Control Select Desired Region Using Up / Down Arrow Keys (0 [Zero] For Region Free)
Hope this helps.
Jun 18, 2011 | DVD & Blu-Ray Players
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Nov 21, 2010 | LG RH-4820 DVD Recorder
How do i unlock the region code on my awa dvd player model ds-a331
Got this one from the AWA tech - it worked for me
Turn Off Player
Turn On Player
Tray Should be closed
Using the remote choose 'Setup'
Using the Left/Right Arrow Key select The 'Preferences' Tab
Key in 8737
You should see a Box with the current Region Code
Use the Down Arrow key to change it to 0 (assuming you want region free) or select another number for a specific region
Hit enter (the play key) to exit this menu
Turn player off
Turn player on
load Disc
Oct 09, 2009 | Philips DVP5140 DVD Player
Region code for DVP 3986K
try 2 steps
Hack is the same as the DVP 3960
Press "Setup"
Scroll to "Preference page" using the Left/Right arrow key
Press "138931" and a popup screen will appear
Use the Up arrow key and select 0 for a region free DVD player
Get her up and running.
Press "Setup" on remote control.
Scroll to "Preference" using the right arrow button on your remote.
Press "138931" and a menu will appear.
Use the Up arrow key and select "0".
Nov 11, 2008 | Philips DVD625 DVD Player
Tryed the code to unlock region
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
DVP 5106k
1 - Make sure there is no disk in the player
2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!!
3 - Press MENU (System) on the remote
4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen
5 - Now enter the sequence 135566 with the remote control
6 - Now "Region Code" should appear
7 - Select the 0 (multiregion)
8 - Press MENU (System) on the remote to exit the setup screen
9 - Press the power button on the remote to set the player on standby, this saves the new setting.
Apr 19, 2008 | Philips DVP5140 DVD Player
Wrong disc message displayed on screen for dvd-2026
I found these posts. I have only been able to get the fix to work once, though. :(
I found a "hack' to make mine work :)
1. Open the tray
2. Press "Setup": Menu Screen should appear
3. Press "8-8-8-8" ( if you changed the password, you might have to change it back to 8888 ) The region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region to 255 for all regions.
5. Use the up or down button to go to 3001 and 4000. I had to change 4000 to 4001 to get mine to work,
6. Press "Setup" to exit.
It was a big relief to find this hack, because I misplaced my receipt and thought I was simply out of $30.
Region code hack posted by jeff777, December 15 2004:
This works.
1) With remote control, power the DVD player on.
2) With remote control, open the DVD tray.
3) With remote control, select SETUP.
4) With remote control, press the VOLUME UP button, then the VOLUME DOWN button, then the VOLUME UP button again and finally the VOLUME DOWN button again.
5) You should now see a number 2 on your screen. If you do not, this hack will not work on your system or you have done something wrong. If you do see the number 2 on the screen, proceed to 6).
6) Use the LEFT and/or RIGHT arrow to select the number 255.
7) When you see the number 255, press the SELECT button.
8) Press the SETUP button again to end procedure.
Region code hack posted by RayH, May 18 2005:
Newer Sungale 2026 players are a bit easier to set up:
1. Open the tray
3. Press "8-8-8-8" Region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region. "255" all region.
5. Press "Setup" to exit.
Tested Region 1, 2, 3, 4, and 5 PAL and NTSC disks. They all work just fine on an older US NTSC TV. It's a little bigger than the Cyberhome, but works much better. There is no jerking at chapters with either factory or homemade discs. Plays VCDs just fine.
Sniff around the internet. This machine is availabe as of 5-18-05 for about $29 plus shipping ($11). Arrived in two days.
Other hack posted by Hurricane, January 23 2006:
If you do the Setup>8888 thing you get a region code 1-6 & 255.
Well if you press up and down on the directional pad you also get 3001 and 4001 these can be changed to 3000 and 4000, I know that one of them is a Macrovision on/off flag but I don't know what the other is.
Region code hack posted by Streetmedik, March 25 2006:
I have the Sungale DVD2026 I have tested this with DVDs from various regions. It works.
1. Power on
2. open the tray.
3. ON THE REMOTE press the VOLUME up, down, up, down.
5. ON THE REMOTE press the up and down arrows to go between the macrovision/region codes.
6. ON THE REMOTE press the left and right arroes to change the values.
3001 on
3000 off
1,2,3,4,5,6 = individual regions
255 = all regions
7. ON THE REMOTE press setup again and you are set.
You can change these values again and again If you just want to play around.
Mar 22, 2008 | Sungale DVD-2026 DVD Player
Insignia NS pdvd10
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
Jan 09, 2008 | Insignia NS-8PDVD
Phillips dvp1013
To make it multiregion, follow these steps:
Press "Setup" button on remote.
Scroll to "Preferences" using the LEFT/RIGHT arrow key.
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number.
You can select a specific region (1 through 6) or region "0" for all regions.
Dec 30, 2007 | DVD & Blu-Ray Players
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
47 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
