Simply enough, try going to system restore in the control panel under "Performance and Maintenance" then on the "System" choice look to your left top. there will be System restore unless you've changed to classic view, then you'll have to look at all the icons till you find it. Go back to the nearest day(in bold print) before this started and you should be all set.
This is a windows stop error. Are you running windows XP?
If it is the first time you have seen it you can try restarting and it may never appear again. If it does:
At the bottom of the screen you will see some text saying STOP ERROR: 0x000000?? (0x???????? 0x???????? 0x???????? 0x????????)
Look at the code prior to the brackets 0x000000?? - write it down and google "STOP ERROR 0x000000??".
This will let you know what is causing the STOP error. Very common reasons for this are component reseating required and disk-checking. You can run a diskcheck through the Windows Recovery Console (can be installed to hard-disk - simplest way is to install combofix and follow the onscreen instructions - or run from your windows installation disc).
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 9200 PC Desktop
i want class diagram for war room system(chess game)using software requirement specification. its...
(More)
i want class diagram for war room system(chess game)using software requirement specification. its chess game.the game allows only two players to play the game over network.its online game................
I work with hand drawn illustrations that I scan as bitmaps and would like to change theminto vector...
(More)
I work with hand drawn illustrations that I scan as bitmaps and would like to change theminto vector based illustrations to colour them in using either illustrator or photoshop. Open paths are a problem while colouring in the illustrations so how would I close open paths on these vectors?
i have a emachines et1161-01 snid#83701753390 and the REG_SZ data value is not set. can you help me...
(More)
i have a emachines et1161-01 snid#83701753390 and the REG_SZ data value is not set. can you help me set the value for this ???
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
