Question about Kodak EasyShare DX4330 Digital Camera
My kodak digital camera will not download into my computer...the camera stops when cord is attachedc
When I connect the cable to my camera to download into my computer ,,,it does not work
  • 13433 Answers
SOURCE: I have misplaced or lost
By looking at the pictures of your camera. seems you need a stardard usb cable
Click here for a standard usb cable, same that is used in printers.
If you have such cable at home test does the other end fit to the camera if its too big then you need a smaller one.
possibly like this one - click here
if that doesn't look right either look for other cables on ebay.
click here
Just need to find the right shape and type of cable, there are not that many diffrent possibilities, theres no need to buy a brand new over priced one from kodak directly. in the end, its just 4 wires inside a black cable.. noting special.
Posted on Jul 23, 2008
  • 133 Answers
SOURCE: Kodak C813 Digital camera and I can't download pics to computer
Hello Katiekakes55,
Here are few steps that you can try
>> Is the camera detected at all by the computer? Do you see the USB Mass storage device connected icon similar to one below in the system tray?
a27e7c1.jpg If YES then do you see the new drive letter in my computer?
If NO then right click on "My computer"--> Properties --> Hardware Tab --> Device Manager
With your camera connected to the USB, do you see any exclamation (!) or red cross (X) on any of the devices? Especially below the USB Serial Bus controller? ... If yes then right click on the device and choose uninstall. Now, disconnect and reconnect the camera to the USB and see if it works now.
>> If the above steps do not work then ... Are there any other USB devices connected to your pendrive or external HDD? If yes then try swapping the ports with camera.
>> When did the camera work with your computer for the last time? Did you make any changes like hardware or software installations/uninstallations on your computer?
Please let me know the answers after you perform the above steps..
Hope this helps .. All the best :)
Please do rate the solution
Thanks and Regards,
Posted on Apr 09, 2009
  • 2976 Answers
SOURCE: I have a KODAK DC240 ZOOM digital camera and no power cord
The Kodak website has them as accessories.
Posted on Jul 31, 2009
  • 85 Answers
SOURCE: EasyShare M853 Digital Camera: I lost my charger cum usb cable of kodak digital c...
go to kodak center os showroom and look for univerasl charger to charge your battery and for the usb you can buy card reader to interface you camera to your pc
Posted on Jun 08, 2010
  • 11967 Answers
SOURCE: my digital camera is the Kodak Easy Share C913,
Solution: Windows should automatically recognize your digital camera and prompt you with a list of possible actions, such as viewing the pictures stored on your memory card. Sometimes, this recognition takes several minutes, especially if you're plugging in the device for the first time. If, after waiting a reasonable amount of time, you are not prompted with actions for your digital camera, ensure that your camera's batteries are charged and that your camera is turned on, as many models require the camera to be powered in order for the computer to access its contents. If these things check out, try plugging your camera into a different USB port. Next, go to the Start menu and click My Computer (in Windows XP) or Computer (in Windows Vista and Windows 7) and then see if your device is listed under the Devices With Removable Storage section. If it is, double-click your camera's icon to interact with it. If not, try the following suggestions.
It could be that in order to use your digital camera with your computer, you must first install the software that came with your camera. If you can’t locate the software disc that came with your digital camera, you may be able to download the software from the manufacturer’s Web site.
If none of the above solutions solves the problem, you may need to enable your camera in the Device Manager. In Windows XP, click the Start menu and choose Control Panel. Click Performance And Maintenance, click System, and choose Device Manager under the Hardware tab. In Vista and Win7, click Start and choose Computer. Click System Properties at the top and then choose Device Manager from the left menu. Locate and expand the Disk Drives entry, right-click your camera’s name, and choose Enable. Once enabled, your camera should be recognized and listed in My Computer. If your camera is still not recognized, we suggest you contact your camera’s manufacturer for additional suggestions.
Posted on Jun 29, 2010
  • 93807 Answers
SOURCE: my kodak digital camera will not download into my computer...the camera stops when cord is attachedc
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Oct 27, 2012
0 characters
1 Points
I have a Kodak EasyShare Z981 camera. It says my internal memory is full. What do I do?
You have to transfer the pictures and videos in the internal memory to your computer.For this you have to download and install Kodak software on your computer.
( Make sure the computer is connected to the Internet. When you connect the camera to the computer, the KODAK Software Downloader automatically runs. Follow the prompts to download and install KODAK Software.)
Please follow the steps below to connect your camera to your computer;
1. Turn off the camera.
2. Use the KODAK Camera USB Cable, U-8 to connect camera to computer. (Use only the cable included with this camera!)
3. Turn on the camera.
After the software is installed, follow the prompts to transfer pictures and videos to your computer.
* If the downloader does not run, find and launch it:
• WINDOWS OS: in My Computer
• MAC OS: on your Desktop
Note: You can use the Memory card to save the pictures and videos taken on your camera.In this case you can also use a card reader to transfer your pictures/videos.This prevents the user from connecting the camera every time to transfer data.Eject the memory card and insert it into the card reader.
Please feel free to ask your doubts.Thanks for choosing Fixya.Your valuable feedback would be appreciated.
Aug 07, 2011 | Kodak EasyShare Z981 Digital Camera
How can i move photos from internal memory
You'll need either a USB cable running from the camera to your computer or a Kodak camera dock connected to the computer, and the proper version of Kodak EasyShare software. The software is available for download, at no cost, at
Dec 21, 2010 | Kodak EasyShare CX7430 Digital Camera
Kindly follow below instruction.
**download Kodak Software for easy transfer of videos to your computer.
(make sure that the computer is connected with the internet) Downloader automatically runs and follow the prompt to download the software.
-Turn off the camera
-Use the Kodak USB Cable to connect camera to computer (make sure that you are only using the camera included in your Kodak kit)
-Turn on the camera
-Follow the prompt to transfer videos to your computer
Hope above tip would help you.
If you want, you can browse the link above for you camera's manual.
Thank you.
Jul 31, 2010 | Kodak EasyShare M530 Digital Camera
I dont know how to put pictures on the computer from my camera
Dear Bernaaklt,
You will need a USB cable to link your camera to your computer. You can go to any camera or computer store nearby and take along your camera, so that you could buy a usb cable.
You could also order it on line, just google "USB cable for Kodak Easyshare M1063 camera".
Let me know if I can be of any further help.
Mar 10, 2009 | Kodak EASYSHARE M1063 Digital Camera
Fujifilm z10 Will Not Connect to Computer
Your computer might need the driver for that particular camera reinstalled. You should be able to go to Fuji's website and download an updated driver for your camera make and model. Also, just to be sure, most cameras have to be turned to the ON position when you download data. My Kodak will not communicate with my P.C. unless I have it ON when I attach the U.S.B. cord - a couple of times I have sat there waiting and nothing, until I realize I did not have it ON. Also you may want to make sure your U.S.B cord is O.K. - replacements are inexpensive. Good Luck!!!
Nov 07, 2008 | Fuji FinePix Z10fd Digital Camera
Lost my cords during a move
753 has a special mini usb cable only from kodak-buy a 20.00 sd memory card reader and use that to download-they work great!
May 20, 2008 | Kodak Easyshare M753 Digital Camera
Downloading photos compatibility to a windows vista computer
ya i think it will download connect your camera to pc and see if it automatically detects that ,i think there will be cable given to you connect it to your pc and camera install the drivers for your digital camera ,if you dont have that download it from kodak site
Feb 12, 2008 | Kodak EasyShare C340 Digital Camera
Kodak EasyShare C613
There is a certain thing you can buy that has a cord that hooks up to your computer, and then you put your camera in the little holder and it uploads. BUT if you dont want to spend your money on that, yes you need a USB cord to upload. Your camera should have come with A USB cord, manual,CAMERA (:, a software disk, etc.
Dec 13, 2007 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare DX4330 Digital Camera Logo
55 people viewed this question
Top Kodak Digital Cameras Experts
Are you a Kodak Digital Camera Expert? Answer questions, earn points and help others
