Have you tried locking all the doors windows up then using the door key not the key fob if you have one. Put the key in And manually unlocking the door this usually resets and disarms the security system in most modern vehicles. The alarm and security system will continue to function properly but this a a manual override to shut down the security systems sensors and make the audible alarm system to reset and stop sounding the ala
If your motion detector act like a door it is because it has been program like a door, you need to go back to the program delete your sensor, and reprogram it with a group 17 , right now it's probably program as a group 13 ( instant)
Check all ur windows and doors sensoring connections,might need to be changes.Weather is too hot or too cold,will trigger the alarm.When u arming tries by passed and any error codes for doors or windows connections codes.This should stop the fault alarm by the expanding and contracting sensors by the weathers.
I am sure you already guessed this but it appears someone has changed the default installer code. Using the default installer, dealer, or master codes defeat the purpose of a security system as most criminals know the default codes. The only way I know of to regain control of this panel is to reset it to factory defaults. This does mean that you will have to completely re-progam the system. I would document as much stuff as you can from the display before resetting it. If you don't have a copy of the installation manual I am providing a link below. Hope this helps.
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
it is detecting a problem....could be a dirty key or bad chip in the key....try this.....set the alarm by locking the door using the power lock switch and then close the door...the security light should come on steady for about 2 minutes and then go out.....the alarm is armed at this point.....you can unlock the drivers door using the key to reset the alarm.....if you do this with the windows down you can open the door from the inside to set the alarm off and see if it works properly by flashing lights and horn....after you trigger the alarm you will have to reset it by using the key on the drivers door....
I have yet to test it but I think I've figured it out... I spoke to the place I bought the alarm from and he stated that for both the door/windows & motion to arm, you have to leave the house (or activate an exit door) or the alarm thinks you are still in the house. Since the motion is instant on, this prevents you from accidentally setting off the alarm if you armed it and never left.
So what if you want to arm both and stay inside? There is an option called Unvacted premises (in the Timers menu). It's on by default and makes the alarm behave as described above. Set this option to off and you should be able to set both and not leave the house.
I own a security company and can help you with this, but will not have access to Simon mnuals until tomorrow. This needs to be completed through programming.
