Question about Microsoft Xbox 360 Console
When i turn on my xbox the tv shows the message NO SIGNAL, but the machine still makes all the noises of loading the game that you normally hear, but there is just NO PICTURE. help plz thanx in advance.
  • Microsoft Master
  • 19,396 Answers
To start check the video cable and use the Source/Input Select button on TV to check if problem depends on TV setting.
The problem can be a jammed Xbox, a cable problem, or a fault concerning XBox video adapter.
If the XBox was already working on this TV, and you did not change video settings I would exclude incorrect video settings as possible cause for the problem.
To reset the XBox unplug the power cable for ten minutes.
To exclude the chance of a cable problem, try a different cable, possibly using also a diffenrent connector.
If that does not work, test the console on a different TV, if it still does not work, the XBox may have a faulty video adapter (located on mainboard), in that case call the Microsoft support number listed on manual .
Posted on Jul 23, 2009
I installed homefront onto my hard drive to make my xbox 360 quieter but it doesnt say 'play from hard drive' and so i just select 'play game' and then it makes the same amount of noise....
You don't -play- the game from the harddrive, and nor does it make less noise if you install it.
When you install a game to your harddrive, it normally makes the game quicker to load, not for older games, I think Homefront is a "newer" game.
The benefits of installing the game is that your optical reader is less in use, that the game saves and loads quicklier and is normally better performance in-game.
Sep 25, 2011 | THQ Homefront for Xbox 360
Will not read disks. Cycled power usally worked not this time.
First Turn your X-box on
Second Take out your game or CD
Third Open tray
Fourth Close tray
Fifth Repeat Third and Fourth a couple times and let it load then open
Sixth Stop when you hear the xbox make a spinning noise like when it is reading a game
Seventh Open tray
Eighth Pit a game in
Ninth Close tray
Tenth Play you game!
Dec 30, 2010 | Microsoft Xbox 360 Console
I know it is normal for the console to be making a
is there plenty of room around console so it can get plenty of air through the fans,it sounds like it overheating and emight get 2 red lights,placing it on a hard surface with aboput a foot gap all around should sort it.hope this helps
Apr 06, 2010 | Microsoft Xbox 360 Console
My xbox cuts on abut wont connect
I'm thinking bad AV cable or bad port on your TV. I assume the Xbox dash board won't come up, if so the "no signal" message is a TV error message not an Xbox error message.
Try a different port on the TV and/or a different TV; also try a different AV cable.
Good luck. Please rate, thanks.
Mar 05, 2010 | Microsoft Xbox 360 Console
Makes sound like game is hitting something
If the games are not getting damaged this is normal xbox 360 dvd drive noise, the best thing to do is save game to hard drive, you will still need to have the game loaded but it does not spin which eliminates all the noise all you will hear is a slight buzz from the fans.
Let us know if this solution worked for you.
Jan 12, 2010 | Microsoft Xbox 360 Console
My 360 plays all games except this one
Check if your new cd has an uneven surface , like it's bent . Is the grinding noise occuring for all the other games ?, if yes you should check your Xbox's CD reader head .
Oct 04, 2009 | Microsoft Halo 3 for Xbox 360
Why does my xbox 360 make a loud noise when turned
try putting it into your TV if you have inputs and if you dont have any on your TV try a VHS player and put them in and scroll down to the channel L2 it will say that on the top right corner of the screen
Jul 29, 2009 | Microsoft Xbox 360 Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
Xbox 360 malfunction
call 1-800-4myxbox see what they say, you might be under a warranty that will cover it.
Mar 28, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
