Question about Timex Expedition 84601 Wristwatch
Resetting Watch how do i reset timex expedition with digital compass after battery replacement?
Re: Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Posted on Jun 14, 2012
Re: Resetting Watch
    Problem Solver:
  • 7 Answers
Re: Resetting Watch
0 characters
3 Points
The compass on myTimex WS4 fails to calibrate. Have tried removing the battery and resetting everything but still no joy. Is the any other way to calculate the compass?
There is a process to make an all reset. After the reset try again. The user user manual can be downloaded from Timex. Make very sure the watch is absolutely flat and far from metal objects. Even being near most furniture can effect the reading because they can have metal springs. Many homes have a lot of metal in their construction. It's best to calibrate the compass out doors away from power wires or cars or anything metal. On the street you can have metal under the pavement.
If this does not work call Timex. There have been instances where the compass module or sensor had to be changed. I have the same watch. It's a very good one.
Sep 25, 2014 | Timex Expedition WS4 WideScreen 4...
Resetting t40611
Proabably it is "stuck". I often find that a sharp flick or two with my finger on the face of the watch will cause it to start running. Should not need "resetting".
Aug 13, 2014 | Timex Expedition Digital Compass T40611...
I set the alarm turn it on but get no sound from the alarm.
Yesterday, I have just replaced new battery of CR 1620 but it gets no sound as you. I found that it must be resetted that I don't know how. I'm trying to find it out.
Mar 11, 2014 | Timex Expedition Digital Compass T40611...
I have Timex Men's T45181 Expedition Analog and Digital Combo Watch. i want to know how to use the compass directional ring
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639
Nov 06, 2010 | Timex Expedition 84601 Wristwatch
Timex Expedition E-Instruments E-Compass Watch
Timex makes its manuals available for download from their website:)
Sep 21, 2009 | Timex Watches
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
Sep 14, 2009 | Timex Expedition Adventure Tech Compass...
No beep, no alarm, no sound at all after battery replacement and after resetting the watch. The watch is the Expedition.
I think you put case back wrong way ,, or a small spring which connect caseback with watch movement feil during battery change that also ma be a issue.
203 N. LaSalle St
Chicago, IL 60601
Ph: 312 641 7000
Sep 14, 2009 | Timex Digital Expedition watch
I'm looking for a watch strap for a ladie's Timex expedition Adventure Tech watch. Where do I find one??
Timex stores are the only place I have been able to find their straps consistently. If you have a standard lug set up you might be able to get a similar after market strap at your local repair shop.
For Timex locations visit their web site...
Sep 12, 2009 | Timex Expedition Adventure Tech Compass...
Timex expedition compass battery replacement?
i am not an expert in this particular case but i followed theses below steps . here are they.....
Unscrew the case back with a case back tool (aka Jaxa wrench) which engages
the notches in the case back. I'm assuming the watch has a screw back - if
it has notches it does. Pop out the old battery.
In some watches you have to
unscrew a clip but in most the battery pops right out. Examine movement for
evidence of battery leakage or other damage. Carefully clear away any crud
at the edge of the case - the tiniest metal shaving will short out the coil.
Install new battery of same type. Handle new battery with non-metal tweezers
or rubber gloves, never bare fingers. Inspect case back gasket or preferably
just replace it with new o-ring of same size. Gasket should be lubricated
with silicone grease. Reinstall case back using wrench. If you are
concerned with water resistance the watch needs to be tested in a pressure
test machine. I'm sure the pros have more tips but this should suffice for a
Timex where it would not be a big loss to damage or break the watch.
i hope you can successfully replace the battery
thank you
Sep 06, 2008 | Timex Digital Expedition watch
Timex Expedition 84601 Wristwatch Logo
1,858 people viewed this question
Top Timex Watches Experts
Ross Keen
Pieter Vleeshouwers
Are you a Timex Watch Expert? Answer questions, earn points and help others
