Question about Nakamichi SoundSpace 8 CD Player
The clips on my speakers snapped so now the red/wht cables cant be attached properly, where do i buy these clips?
    Genius:
  • 1,550 Answers
Radio shack
Posted on Jul 23, 2009
I have a mazda mvp 1993 v6 and i need what each coler and what eachean for a radio help me
If this is a new radio you are installing, these are the existing Mazda connections:
In joint box: BLU/BLK wire from 15A CIGAR fuse (accy/run power); BLU/RED wire from 15A ROOM fuse (always hot power).
LF speaker: RED and RED/BLK; RF speaker: RED/YEL and ORG/BLU (or RED/WHT); LR speaker: BRN and BRN/WHT, RR speaker: BRN/YEL and BRN/BLK; L door woofer: GRN/BLK and GRN/ORG; R door woofer: GRN (or GRN/WHT and GRN/RED
Sep 27, 2012 | Dual New Xr4115 Mechless Digital Media...
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
I have my amp hooked up right to two 12 inch subs but the red protect light comes on wht does this mean?
Check all your cable work.
Power is connected tight? Ground is attached tight - on both ends (my guess is it is the ground) Remote cable?
Is the ground a proper ground?
Mar 01, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Stereo wiring for a 91 honda accord
1. red/blk ---------lighting switch
2.wht/yel-----------to fuse No.24 (7.5A) under hood relay box
3. yel/red---------- to fuse No. 11 (10A) Dash fuse box
4.brn/blk ----------- (--) R front speaker
red/grn ----------(+)
6. brn/blk-------------(--) L front
blu/grn
7.brn/wht -----------(--) R. Rear speaker
red/ywl-------------(+)
8. gry/wht----------(--) L..Rear
blu/yel ----------(+)
9.BLK----------------- to the ground.
Apr 05, 2010 | 1991 Honda Accord
Need to remove driver side door panel?
  1. Disconnect the negative battery cable.
  2. If equipped with an accessory switch panel, carefully pry the switch panel up and away from the door panel. Tag and disconnect the switches from the panel.
  3. On 1981-86 models, remove armrest attaching screws.
  4. On 1987-96 models, remove the retainer screws secure the pocket in the molded armrest on the door panel.
  5. If equipped with crank type windows, remove window crank handle with the appropriate clip removal tool.
  6. If equipped with manual remote mirrors, remove the control knob bezel.
  7. Remove inside door handle cover attaching screw and trim plate.
  8. If equipped with door mounted speakers, remove the speaker, and disconnect the speaker wires. For speaker removal and installation steps, refer to .
  9. Remove all external screws securing the door panel. Insert an appropriate prytool between the door panel and door frame to remove the hidden clips securing the panel.
  10. Holding door panel vertical lift straight up to release the upper clip.
  11. Inspect all retaining clips and replace any broken or missing pieces.
To install:
  1. Position the door to the door and carefully press on the retainer clips to engage. If a clip will not engage, inspect the mounting hole behind the panel to make sure the clip is properly aligned. Install any panel-to-door retainer screws.
  2. If equipped with crank windows, attach the washer and crank to the window regulator stud.
  3. On 1981-86 models, attach the armrest to the door using the retainer screws.
  4. On 1987-96 models, insert the armrest pocket and secure in place with retainer screws.
  5. If equipped with door panel mounted speakers, attach the speaker wires to the speaker and secure the assembly to the door panel.
  6. If equipped with remote cable mirrors, attach the control knob to the door panel with the retainer bezel.
  7. If equipped with an ashtray, insert the holder assembly, and secure in place with retainer screws. Install the ashtray to the holder assembly.
  8. Position the door handle trim panel around the door handle assembly, and secure in place with the retainer screw.
  9. If equipped with accessory switch panel, attach the harnesses to the switches, and press the accessory plate into the door panel.
  10. Connect the negative battery cable.
  11. Check and make sure all panel components function correctly.
Apr 03, 2010 | 2002 Ford Explorer Sport Trac
Our dlp tv shows great color when watching tv but when we watch a dvd the red is brown and the pink is tan? HELP
if you already check your cables.. and it's still the same.. the problem is probably the VIDEO BOARD
here is a picture of what is a video board..
Nov 28, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
We need the colors of the speaker wires
I can email you the diagram...would be easier for you to see...but here it is in writing (we can't post pdf. files).
Right Rear Speaker-- yel/red & grey/red
Left Door Speaker -- wht/blu & blk/blu
Left tweeter -- org/blu & Brn/Blu
Left Rear Speaker -- yel/blu & grey blu
Right Door Speaker -- wht/red & blk/red
Right Tweeter -- org/red & brn/red
Jun 29, 2009 | 2003 Mitsubishi Eclipse Spyder
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
Main Speaker cables
well man i would clip the ******** with a few inches of wire attached so you can strip both ends where you cut and splice in a piece of wire it will function properly
Aug 13, 2008 | Sony MHC-GX9900 Shelf System
Nakamichi SoundSpace 8 CD Player Logo
87 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
