Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Recovery kits for Compaq Presario SR1050NX - Compaq Presario SR1050NX (DW257A) PC Desktop
  • ammar_99 Jul 25, 2009
    Yes,I do
  • Rik Evans May 11, 2010
    Do you need a recovery kit for it?
  • Compaq Master
  • 32,281 Answers
Recover CD can be purchased from Compaq. Contact them and provide details of the model number details etc.
Posted on Jul 23, 2009
  • Chris Hingee
    Chris Hingee Jul 27, 2009
    The recovery CD you need is specific to your model laptop, any recovery CD most likely won't work with your laptop. You need one for your model laptop from HP/Compaq.
I want to restore my compaq presario SR 1050NX to factory but it is asking for administrator password and I didn't put one on
Try admin or just hit enter. If not remove the battery from the mother board for 5 minutes and see whether it helps. If you haven't entered a password on BIOS there shouldn't be any problem. Also try deleting if you have any other users accounts on the system.
Good Luck!
Jun 09, 2011 | Compaq Presario SR1050NX (DW257A) PC...
Compaq presario sr1050nx will not power on and the green light just flickers.
I have the same SR1050NX compaq computer with the same startup problem. I suspect this from a code seeded in the system, so performed the system recovery for several times. The problem gradually came back, automatic shutting down with loger interval. I thought the bug is in the recovery system. But the floppy drive in the cmos is disabled without choice to be activated. So, I couldn't perform FDISK at DOS mode. For this computer, I wonder anyone knows how to activate the drive for boot order besides through the setup window.
Thanks very much.
Josh
Nov 12, 2010 | Compaq Presario SR1050NX (DW257A) PC...
Will a AMD Athlon 64 processor work in a Compaq Presario SR1050NX Desktop? My old processor Died and I purchased one of these off of Ebay, now just want to make sure it will work...
No Donnie, the motherboard for the Compaq Presario SR1050NX won't support an AMD Athlon 64 processor.
The reason why is;
A) The Processor socket on the SR1050NX's motherboard is a Socket A. (Also known as Socket 462)
Hp Support > Compaq Presario SR1050NX > Specifications > Motherboard Specifications >
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00072236&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=405454
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short.
Look to the right of the CPU heading:
Socket A (Processor socket)
This is the Socket A processor socket used on your motherboard,
http://en.wikipedia.org/wiki/Socket_A
You can click on the photo of the Socket A processor socket, to the upper Right, to enlarge.
The AMD Athlon 64 line of processors came out after the Socket A, and used the Socket 939 first.
Then on to the Socket AM2.
(Socket 940 for some models)
List of AMD Athlon 64 Microprocessors,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors
http://www.weirdstuff.com/cgi-bin/category/10201
Oct 12, 2010 | Compaq Presario SR1050NX (DW257A) PC...
Full format of compaq presario 2100
Most notebooks have a separate partition on the hard drive that holds the recovery media needed to restore the unit.
You can usually run this by pressing F10 during the boot up process. You may need to press it several times in order to get it work.
If that doesn't work, then you will need to contact Compaq in order to order the recovery media kit.
May 09, 2010 | Compaq Presario Notebook
Need audio driver
why not go to the compaq website and put in the name of your machine? they will direct you to the appropriate drivers for your whole system and you can save them on your hard disk in a location you pick, then you can upgrade anytime.
Jun 25, 2009 | Compaq Presario SR1050NX (DW257A) PC...
Start Normally (black screen with options)keeps re-loading itself
If you can't get into windows normally or into safe mode to try to restore the system back to a date when it worked properly then you'll need to wipe out the hard drive and start the system from scratch.
Feb 08, 2009 | Compaq Presario SR1050NX (DW257A) PC...
On my desk-top presario
HP/Compaq has had alot of power supply issues with this series of computers. Do you have another power supply you can try in this system? If the light is flashing rapidly, it is usually a power supply. Fairly cheap and easy to replace.
Jan 26, 2009 | Compaq Presario SR1050NX (DW257A) PC...
I cant install the ethernet driver on my compaq presario sr1050nx
go to 'support' at www.hp.com and look for dirvers for your model. There should be a driver for the 10/100 tbase ethernet device. Download and install it and reboot. Should fix the problem if the ethernet adapter is working.
Dec 12, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Compaq presario SR1055CL
ok mary this might be a virus issue we have to forrmat the HDD....compaq ships the copy of the operating system with the system in the D: drive so we need to restre it back t the factory settings...so go ahead and run a recovery .....restart the system and keep tapping F11(vista) F10(xp)......it will take u to the recovery manager and the n click on advanced option and select the option system recovery......and select next and then select recover without backing up and then click on nect and it will now format the HDD back to factory settings and your issue will be resolved
Mar 19, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Motherbooard for Compaq Presario sr1050nx
A7 indicates that it is a K7 series - a socket 462. Socket 7's were for the old Pentium 1's and AMD K5, and K6 I,II, and III series of pre-athalon processors. Socket 7 was also the last socket to see Cyrix chips.
Oct 15, 2006 | Compaq Presario SR1050NX (DW257A) PC...
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
143 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
