Toshiba TEC B-472 Thermal Label Printer Logo
m
manfred boeck Posted on Mar 02, 2017
TEC Toshiba B 472 - How to change firmware?
We have some TEC Toshiba B-472 Barcode Printers, one with defective motherboard/RAM (- after power on some labels are okay, then the printer does not stop printing, RAM CLEAR/RESET did not make any change). We changed the motherboard using a board from a TEC B-572 printer (- for this printer printheads are no longer available), which has exact the same part number and also the same firmware 3.4, - but the print image is distorted and the print head is reported as defective (- as the 572 has had a 300dpi print head). How to get the original firmware from the one board to the other board (- board seems to have fixed Flash-ROM) ??? I asked TEC Toshiba - but got no answer.
2helpful
Error sign shows On Error shows: SG;0015,0404,044 after press restart shows: SG;0015.0036.048
Change graphic settings to 8 bits or 4 bits instead of Topix compression in the driver.
Firmware too old to understand the instructions.
Troubleshoot tec barcode printer
Download windows driver from www.bartenderbarcodesoftware.com
define the pages et label size in the driver, check that you have validated the coreect use (direct or thermal transfer) gap, black mark etc..
Once the driver install , you can use ssdal send file.txt to snd a file to the printer. Check with the help /? option
Tec b-472 gap sensor
use detection transmissve in the driver
In the display show the next message: "PROGRAM
This is due to your microswitch or firmware problem.
Check if switch 1-7 and 1-8 are off
Otherwise your printer needs service
1helpful
Cannot print graphics accurately. Barcode and text
Problem with your software.
Tec do have instructions for printing diagonals.
Your software must be sending graphics with grey pixels.
TEC B 472 QQ
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
TEC 472 QP PRINTER
Try with CUPS --- oh, sorry, it's for Linux only, my bad
Top Toshiba TEC Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
