SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
SOURCE: manual for tricity bendix 1000
Please try here:
http://www.serviceforce.co.uk/pdfs/U23248.pdf
If this is your model (there are 5 models with the same name) please rate my response.
If not, please let me know and I will find the link for your model.
Thanks.
SOURCE: belt route on tricity bendix 310 w tumble dryer
These links should help out.
http://www.affordableappliance.com/Tips/beltdiagrams.htm
http://www.affordableappliance.com/helpful.htm
