Frozen lines out side at condenser, blowing hot air inside
  • 3,600 Answers
You have a blockage in the evpaperator.
Posted on Jul 23, 2009
Amana ptac unit blows air, it feels kind of cool, but it's set at 65 and it's not reaching the desired temp... does it need 2 be recharged or are my lines possibly froze...???
If the unit is frozen you should be able to see ice at the indoor coil. If you pull the air filters and peer inside to the indoor coil there may be ice. Either way it needs service. If no ice and blowing cool not cold it could be the condenser coil is dirty. On the outside you can see the air leaving side of the condenser coil. The air entering side is the side that gets dirty and can only be seen by pulling the unit out of the wall. Its best to leave it in the wall and call a tech that has experience with ptacs.
May 23, 2015 | Amana Heating & Cooling
My Kenmore 50542001 side by side freezer has defrosted and fridge side seems to be working
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Feb 09, 2015 | Kenmore Refrigerators
Why Samsung fridge has condensation around water/ice dispenser and drips every few hours?
Jul 16, 2014 | Samsung 25 Cu Ft Capacity Stainless Steel...
I have a samsung refrigirator side by side with a bottom freezer door. It is leaking from the bottom of the right side of the freezer right of the free
Freezer /fridge water/ice in fridge and or freezer
Jul 15, 2014 | Samsung Refrigerators
Water not coming from gss25lgmb bb
I have a GSH25JSRFSS GE refrigerator. Twice, the water line has frozen near the dispenser. Each time I used a hairdryer to heat either the side of the door where the water line runs and blew hot air up the dispenser. This last time, I took the plastic cover off the outside of the door (it clips on) and blew hot air into the small holes in the door that the outside grate clips into. This allows the hot air to get inside the door, and I heard ice from the frozen line drop. Subsequently, the water line worked. Two points: I did have water running to the line in the bottom of the refrigerator, so I knew it was an ice clog, and secondly, I took care not to blow hot air on the exposed wires inside the door.GKAZ
Oct 23, 2011 | GE GSH25JSRSS Stainless Steel Side by Side...
Just cut on 8 year old Goodman CPLE24-1 AC for the summer. Ran 8 hours fine, Next morning noticed outside unit running, very little cool air blowing out of inside floor vents (like the blower fan was...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Apr 12, 2011 | Goodman CPLE24-1 Air Conditioner
Why would my Chest freezer be flooding my basement while it is still frozen inside
freezers still make condensation like air conditioners. they have a drain line heater to keep the condensate liquid until it exits the freezer. then it goes into a drain pain that usually has the high (hot) side line running through it to evaporate the water and at the same time increase efficiency. you probably have a rusted out drain pan which you can replace. you can make one from sheet metal and just seal the corners with RTV silicone, be careful sheet metal WILL cut you badly, so wear gloves whenever handling that stuff.
Oct 10, 2009 | Freezers
Kenmore Elite Coldspot side by side Model # 106.57706701 Frdige warm, freezer is frozen up. Have removed back panel several times in ther freezer to defrost coils and several weeks later, same problem.
check the fan that transfers the cold air from the freezer to the fridge. thats where it comes from if you didn't know that. also check the the fan on the condenser at the bottom of the fridge. it should be blowing hot air off the condenser to facilitate the elimination of the heat from the condensing unit, just like your a/c does on the houe.
Jul 20, 2009 | Kenmore Refrigerators
Amana heat/air conditioning pump
You are going to have to increase the amount of heat absorbed by the evaporator coil on the indoor section of your system. First change the filter. Second turn the power off to the outdoor section and leave the indoor fan running until all the ice on the evaporator coil has thawed this could take a few hours. Third you need to verify that you are getting adequate airflow across the indoor evaporator coil and the outdoor condenser coil both fans should be spinning at full speed and airflow should be unobstructed by dirty coil fins or debris Hopefully after you've done this you will have cold air blowing inside and the larger of the two lines entering the unit outside will be cool to the touch but not frozen or even frosted regardless of run time and the small one should be the slightly warm but not hot. If the larger line continues to freeze then it could indicate a number of problems but essentially your condensers cooling capacity is outrunning your evaporator coils ability to absorb heat from air stream circulating in your home.Hope it works out for you GL!
Jun 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Viking Condensate Freezes
most likely the drain is plugged try using some low pressure compressed air to blow out the tube, yes the heater is what defrosts, no hot gas, other than that the icemaker fill tube could be leaking, freezing the drain.
Mar 30, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
