Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Rust marks left on laundry
Soon after purchasing this machine, kight rust marks, the size of the holes in the drum started appearing. these got darker and appear on all items exxept very dark colours. they do not come out.
at firtst the engineers told me it was soap scum and i purchased sachets to clean (new) machine at cost of £39.95!
the problem , i was assurred, would cease. but no. 6 v7 visits later and most of our clothes and linen speckled with rust, hotpoint refuse to replace machine. domestic and general with whom i have an extended warranty policy also refuse to replace machine. i will not now use it.
    Scholar:
  • 61 Answers
This is a weird one, the marks have got to be coming from somewhere, if you are still under your first year of owning it go back to the shop where you purchased it, Its been a while since i looked into this but i think you may still be covered under the sale of goods act or something similar.
if you are now outwith the year keep on calling the engineer out, if you call them out within a month of each visit it counts as a recall and not a seporate visit, after a few recalls they will take notice, alternativley ask for a team leader/ supervisor to visit not an engineer. the best thing to clean out a machine is a boil wash with an old towel and some poweder (the 90 degree wash will bring out the bleach in the poweder and clean the machine internally)
Posted on Jul 23, 2009
My frigidaire dryer keeps leaving these rust color stain on my clothes and keeps putting holes in them. some times stuff gets stuck in this gap between the dryer drum and where the door shuts how can I fix...
replace the drum guides that hold the drum in place these are small plasic guides and they do tend to go with time and use of the dryer this is also what is causeing those rust colored marks on your clothing as well if you are able to message me back your make and model number i can provide you a schematic showing where these guides are located and how to go about ordering new ones for you unit also if you have any further questions message me those back as well and please remember when our chat has concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 23, 2011 | Frigidaire Dryers
My whirlpool washing machine has chipped around the holes in the tub and has rusted. It leave rust marks on my white clothes. Is there any way to repair the tub? The washer is about 5 years old but I am a...
You used to be able to get a brush on product that was used to fix chips in baths and appliances.. I can't remember what it was called, Check around some appliance shops perhaps they might remember?
Feb 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Rusty holes on drum
Hi
If you find a good plasticizing epoxy it should work great for this most plastic epoxies can withstand temperatures up to 500 degrees F. I dont see the hot water supply feeding the machine getting any warmer than this. Another option would be to find someone with a plastic fusion and filler welder and just weld the hole shut with a base material.
OR
Follow this easy steps...
Unplug the dryer from the electrical socket to avoid accidental electrocution.
Sand or scrub the rust spots using steel wool or sandpaper. Rust creates pits and these pits need to be smooth, like the rest of the drum areas, to prevent the rust from getting worse and to allow touch-up paint to stick.
Clean the entire inside of the drum to remove all the dust left from sanding/scrubbing. Mild soap and water will work well. Use old rags that can be thrown away.
Let the drum dry completely. You can run your dryer on the fluff dry cycle for a few minutes to dry the drum faster. If you use a heat cycle, the drum will become too hot and you will have to wait while it cools
Apply an appliance paint (see Resources) in the color that most closely matches your drum. Use the applicator that comes with the paint to dab the paint on the rust spots. You may need to add more than one coat, but make sure that you are letting the first coat dry before adding more to avoid drip marks. Allow all coats of paint to dry thoroughly before using the dryer.
Thanks for contacting fixya.com
Sep 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have water leaking out of the bottom of the drum. We came home one night and the floor and carpet were all wet after running a load of laundry. My husband and I,after cleaning up the mess, investigated...
Could be damage to drum ie hole in it .Pour some water in to it with a kettle or alike, this should tell you..Is it quite old or has damage happened due to coin,,Kind regards...
Sep 29, 2009 | Maytag PAV2300 Top Load Washer
Porcelain drum starting to rust
Contact the manufacturer for advice. I don't know that there is anything to be done about this, such as applying porcelain paint, since it is probably rusted inside too. I had a similar problem a few years back and it got worse over time.
Aug 31, 2017 | Whirlpool Ultimate Care II LSQ9564J Top...
What holes
Open the drawer at the top left of the front of your machine: you will see 3 compartments: right is prewash, middle is for softener, left is for wash. WATCH OUT- these machines do not need as much washing powder as the american models-putting too much soap could damage your machine and lenghthen the cycles.... I use half of what I used in my previous american washer.... do not be surprised either by the spinning cycle: before going full blown into spinning the machine has sensors that perit autobalancing of the laundry. You must not load laundry above 3/4 of the diameter of the drum.
Jul 27, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Rust in the holes in the drum of an Inglis washing
If you live in a rural area and have a well or bad water you may need a water softner installed.Fill your washer and add clr let run for a bit but do not let it drain stop washer then leave sit over night that should take most of the rust out of your tub.
Feb 22, 2009 | Whirlpool Inglis IP4400 Washer
Brown burn spots on Whites
Hot spots in the drum perhaps. Check for a loose heating element.
May 06, 2017 | Dryers
Small dark circles on laundry after washing
if you do cold to warm washs all the time you will get sludge between the drums,try several 95 degree washs with no cloths in it and see how you go .hope this helps.do you use fabric softner.
Mar 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Brown smudges on clothes
Take a look and see if the drum near the door moves up vertically. It shouldn't move more than 3/16ths of an inch. If it does, replace the upper felt seal/plastic slide. The upper seal that supports the front of the drum on the front of the dryer is worn out to the point that clothes can get stuck in the gap between the drum and the front of the machine. This leaves brown wedge marks on clothes. While it's apart, replace the lower felt seal as well.
Apr 20, 2007 | Frigidaire FullFGX831C Size Stack Gas...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
94 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
