Question about Sony DVP-NS300 DVD Player
I sold this DVD player on E-bay and never had a problem with it. The buyer says the remote control doesn't control the unit. Could you give me some suggestions?
  • GARFIELD1066 May 11, 2010
    Did the remote have a switch at the top to switch between DVD & TV?I have a DVP-NS700,and its remote has switch at top.
Screen sez no disc. whatsup?
Posted on Jan 16, 2008
Ok/select doesn't work with magnavox dvd player
Hi, make sure you Comcast remote is in the "DVD" mode before attempting to work the DVD features. If it is still not working. You need to reprogram your Comcast remote to a different Magnavox DVD code because the code it is currently set for not fully compatible. If you need the instructions to reprogram your Comcast remote go here. If you would like to purchase a new Magnavox DVD player remote you can also search on Replacement Remotes for your DVD player's model number located on the back of the unit. If they have it, it will show for purchase.
Sep 03, 2012 | Universal Remote Control Remote Control
I get set 3 when i press the remote and nothing else no matter what i press play etc any suggestions
Try reprogramming the remote so it matches the unit. If you get SET 3 or DVD 3 on the display, chances are the remote's command code is different to the unit, in which case the following may help a bit:
Ensuring new batteries are in the remote, correctly polarised ( + and - ) and with the remote pointed at the unit (while unit is on), press and hold both the [3] and [ENTER/OK] buttons TOGETHER for 5 - 10 seconds, then release. The remote should now fully control the unit.
If it doesn't, check the batteries and repeat the above. The above procedure is a suggestion based on Panasonic DVD recorders and their operation troubleshooting manuals. Give it a try at least.
Aug 14, 2011 | Panasonic DMPBD45 BluRay Player
How do i get into the set up menu? lost original remote only have universal. argh!
Unfortunately unless the Universal remote is programmed specifically for your DVD layer, or any other piece of equipment, you are going to lose some of its abilities. The newer Universal remotes that are sold now allow you to go online and download specific files for specific units, and they will give you back a lot of the functionality you may have lost. Quite often if you get a TV that was built the same year as the DVD player the remote that it comes with will give you a lot of functions you may not normally see. At this point though it may be less expensive for you to buy a new DVD as the new Universal remotes that come with all of the functionality are expensive.
Jun 29, 2011 | Televison & Video
Can i setup my samsung bdc5500 without a remote control
Answer is NO.
most dvd needs to be set by remote control, because they don`t have a menu access botton on the set.
look at E-BAY for a remote control for its kind.
Aug 26, 2010 | Samsung BDC5500 Player
Need the region hack
1) Remove disk (if any) from the player
2) Turn the player off
3) Turn the player on
4) Open tray
5) On remote press 9-7-3-5
6) A box should appear on the screen with a region number inside (1
for players sold in USA)
7) Use Up and Down arrow keys on the remote to select desired region
(0 means region free)
8) Press Enter on the remote. Tray should close.
9) Regionfree!!!
Apr 30, 2009 | Televison & Video
The remote does not work on my cyberhome ch-dvd 300 dvd player. The unit itself is fine
Working remotes for cyberhome dvd players can be purchased on the e-bay website. You can also try having some one look at the unit , it may be a simple problem of cold solder joints or loose contacts with battery holder causing your remote failure. If not for a few dollars you can find a working one on e-bay. I hope this helps you with your problem.
Apr 09, 2009 | Cyberhome CH-DVD 300 DVD Player
Need a new remote control
Go to:
Dec 31, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sony DVP-NS300 DVD Player Logo
125 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
