Question about Sewing Machines
My thread keeps bunching up on the bottom of my material. I have re-threaded over and over, basically took it apart and put it back together and I'm still getting this mess! What should I do?
  • 111 Answers
Bunching up on the bottom means that the upper is not threaded correctly - no upper tension.
Posted on Jul 23, 2009
Thank you Mongo32. However, I have tried every tension setting. I'm wondering if it is broken or if I just need to add some lubrication. Can I use WD-40 or is there a special sewing machine grease? And if that is not the problem, should I try getting it fixed or should I just buy another "inexpesive" machine? I sew about 8 times a year.
Posted on Aug 01, 2009
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Why is my thread birdnesting? i am getting some thread that bunches up under my fabric. I have played with the tension changed needles, and rethreaded both top and bottom
bunching up under the material is loose tension of the needle thread
pull the thread out before you thread the needle and if it doesn't require a small amount of effort to pull then the thread is not between the tension plates or the tension plates are not being allowed to move closer together to add the tension
check that the thread is actually between the plates and not to one side of them
full tension adjustment should make it fairly difficult to the thread by hand
Nov 20, 2015 | Sewing Machines
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Thread bunchingup on bottom of material on singer
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 28, 2009 | Sewing Machines
Feeder not moving thread is bunching up How do
I took off the foot, plate and where the bobbin is kept. Cleaned it out and there was a thread that was caught there. I put it back together and it worked fine.
Thank you
Patti
Oct 29, 2009 | Husqvarna Freesia 415
The tread gets all bunched up on the underside of
Take the thread off the top of your machine and rethread it. Anytime a sewing machine bunches up the thread on the bottom the cause is the top thread. Make sure the tension dial is on "5". After you thread the machine, put the pressure foot down,(like its resting on fabric, but not on the thread), and pull the thread towards the back of the machine. It should be somewhat tight. The needle should "bow" slightly before the thread comes through the needle.
Oct 06, 2009 | Sewing Machines
Thread catching and bunching up in bobbin latch while sewing
I had the same problem where the thread was getting all bunched up on the underside. I took everything out and followed the manual concerning threading, then manually moved my right wheel to see if it would get bunched up. It took awhile, but I finally got it sew correctly again. I;m still not sure what was wrong with it. I have a singer 7470.
Mar 23, 2009 | Singer 132QRFB Mechanical Sewing Machine
Model 8280. The thread on the bottom keeps bunching up. It is a horrible mass of thread. Then, it stops moving. Can you help me?
I had the same problem and I tried everything including removing the bobin case, cleaning out lint, changing the needle, adjusting the tension but it did not work. Then I finally tried reloading the bobin thread, making sure to load the bobin according the manual directions....and the problem was solved...no more tangles... just a nice even stitch...yeah!
Jan 04, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
484 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
