Question about Tomtom One XL GPS Receiver
ALL Voltages (three wires) iones battery of Ton Tom one
My tom tom is broken (internal recarger battery)
My battery (nominal 3.7 volts) is low
The battery have three wires (black,red,yellow)
Please tell me the voltge of ALL wires??? (NO USB !!!!!!)
    Brigadier General:
  • 4,090 Answers
Not sure why you would need to know this , red is live black is return circuit and the yellow is auxilliary and usually goes to charge input. as a live wire It is easier to cut and graft a new battery to the stubbs of wire than to solder new battery on. What you might really be needing is the polarity.. whether any charge pin is positive or negative if you are making a new internal charge point. Consult the back of the charger it usually states the polarity in a graphic.
Posted on Jul 26, 2009
Sam is 5 years old...his older brother Tom is 3 times as old as Sam...when Sam is 20...how old will Tom be?
Well, Tom is 3 x 5 = 15 yrs now. Sam has 15 yrs to go to 20. Then Tom will be 15 + 5 = 30 yrs.
Or, Tom is 10 yrs older than Sam now, so when Sam is 20........
May 15, 2015 | GPS
Trouble with three SM57 having low volume unless directly on sound source
It is unlikely there is anything wrong wit the mics. The SM57 is very simple. Literally just a magnet and coil of wire. The problem that you describe is likely caused by your mixer, the presonus, etc.
Oct 29, 2012 | Shure SM57-LC Professional Microphone
Why does my dr3624 only put out 98 vac, its rated at 120 vac? i'm off grid and my batteries are new 24 volt
Are you using a true-RMS voltmeter to measure the DR's output? The DR's output is modified sine wave, and a cheap average reading AC voltmeter will give you a reading of 90 volts or so. Alternately, if you have an oscilloscope, you can verify that the modified sine wave is around 170V peak to peak. It should alternate in segments of -170, 0, +170, 0... The duty cycle and peak voltages will vary with the inverter load.
- Tom, Sun Electronics International, Miami, FL
Oct 03, 2010 | Xantrex Technology DR3624 Inverter/Charger
Tom tom keeps turning off ?????
The internal rechargeable battery has failed; they don't last forever.
Just search "TomTom One XL battery" and you'll find the the parts and step by step guidance on what to do.
May 28, 2010 | Tomtom One XL GPS Receiver
Why there are three wires in battery of Ton Tom one
You can get a multi meter from an electronic story really cheap.
It will tell you the voltage and the polarity of the battery connectors.
Jul 22, 2009 | Tomtom One XL GPS Receiver
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Tom Tom not working
when i have tried to update my software by using the tom tom cd it will now not come on. you have to remove the card and put it back in or if its on charge the the tom tom will come on
. help please the
Mar 14, 2008 | Tomtom ONE GPS Receiver
Tom tom 300
If the unit is still under warranty, send it back to Tomtom. Even if the unit is no longer under warranty, complain to Tomtom. There is a problem with the CLA (cigarette lighter adapter). It can cause internal damages to your Tomtom. What happens is that there are three wires in the CLA along with a voltage stepdown circuit board. The wire are +, -, and a signal wire. If the signal wire get disconnect the voltage could spike up to 12vdc. The unit is designed for only 5vdc.
If the unit is out of warranty then try the following website for repairs. They can fix the two chips which usually blows.
http://www.satnav-shop.com/
Jan 26, 2008 | Tomtom GO 300 GPS Receiver
How to replace internal battery
Remove the Front facia surround Undo four screws holding internal works to outside body You will need a T6 star screwdriver for this. Remove internal works from body at the base you will see silver foil covering feel over this you will find 4 T5 star screws securing this remove these and also remove speaker by two locating T8 star screws. Gently remove the electronic board keep all locating cables intact You will then see two T4 star screws holding battery holder remove these and the plastic holder .Unclip battery and disconnect from Pcb Board fit new battery and reassemble. .
Jan 07, 2008 | Tomtom GO 300 GPS Receiver
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Tomtom One XL GPS Receiver Logo
839 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
