Question about HTC G1
Sd card is not working
I have a htc g1 and if i insert my sd card its like there is no sd card in it,it is not responding.
    Problem Solver:
  • 6 Answers
Try cleaning the pins of SC Card with contact cleaner or alcohol if you prefer make sure its dry enough before inserting. If nothing happens try detecting it on PC Desktop with proper Card reader, backup files if you still can then reformat thE SD Card. Reinsert in your HTC G1 if successful reformat it again using your HTC G1 to acquire compatabilty on the device.. hope this help...
Posted on Jul 23, 2009
Keeps saying sd card removed when its clearly in!!
i recently bought a used g1 from a friend and tried to insert an sd card but it said the same thing sd card removed the card is fine then i did some researching and found out that the q1 has a sensor in the sd card cover which if it is opened it will say that message now my problem is that the cover is broken so i am currently working on a solution to that but if it is not broken then just try taking the sd card out turn off the phone and insert the sd card and properly close the cover make sure it is not opened even the slightest then turn your phone bak on and it should work unless the actual sd card reader is damaged or the sd card itself. hope this information was helpfull
Feb 28, 2010 | HTC G1 Smartphone
Received G1 replacement phone i put my existing SIM card into the replacement and in the notifications bar it says SD card removed, insert new one. the SIM card works fine in my current G1
Sounds like you are replacing the SD card, not the SIM card. The SIM is underneath the battery. It's a small white rectangle missing a corner.
Feb 20, 2010 | HTC G1
Where do I insert the sd card on the g1 phone
on the sd slot provided on side panel of your phone.
Feb 19, 2010 | HTC G1 Smartphone
Where do i insert the sd card in the G1 phone?
slide up the keyboard, on the bottom right side you will see a small covered slot, remove cover and insert sd card.
Nov 05, 2009 | HTC G1
Removed SD Card is everpresent in the notification bar on my Tmobile G1, even with a microsd card in the memory slot
Your SD card is corrupted. Since it's corrupt (or worse, broken), the G1 won't be able to mount it to your computer via USB and you will have to insert it into your computer via an adapter. From there you can format the drive (make sure it's formatted fat32) and it should be fine. I've fragged my SD cards a couple of times and had to format. If you are unable to re-format the SD card, then there may have been some sort of actual, physical damage to it, although that's unlikely.
Aug 23, 2009 | HTC G1 Smartphone
Saying Insert SD Card When Its Inserted
well i had the same problem so i took it to tmobile and the guy on the register inserted a new SD card and he said that my old SD card was ful. so i ask him how can i clear it out and he showed me this lil usb SD card reader that they sell at the store and it was 9.99. but other then that basiclly it means that your SD card us full and you just hook it up to the usb SD card reader and plug it to any computer and go back and clean your files and re-use it again. thats about it. hope that help! : )
Apr 23, 2009 | HTC G1 Smartphone
Hey my problem is when I took out my sd out the g1 with out unmounting and when I put it back it say plz insert sd card but when I go to the sd settings it tells me the space I have available and...
it is just a notification...if your information shows up in sd settings and if all of your items from your sd card are working i.e. music, pics, etc. then it is mounted just close the notification...or sooner than later it will close out itself...rate me
Mar 04, 2009 | HTC G1
Syncing music to htc g1
maybe the sd card that you are using is a micro sd hc and if it is that it mont work
Mar 01, 2009 | HTC G1
G1 wont take pictures
I  had a similar problem, I fixed mine by formatting the SD Card in my computer, installing it into my G1, then restarting. You miss out on whatever was on the SD Card from Google, but at least you get to use the camera.
Hope this helps, Eric
P.S. I've called tech support to see if I can re-download whatever was on my SD Card to begin with, and as of yet there is nowhere they could direct me to, to download whichever files were stored there.
Dec 21, 2008 | HTC G1
Camera on g1 does not save to sd card?
The camera ONLY saves to the SD card at this point. It will ask you to insert a card if you do not have one inserted.
Dec 09, 2008 | HTC G1
HTC G1 Logo
569 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
