SOURCE: Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
SOURCE: CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
SOURCE: how to set the tax rate
Its easy just type in the tax rate that you want, then hit the rate button. Afterwards leave tax+ pressed and you should see the tax % sign appear above the number you punched in, and THATS IT!!! Easy!!!
SOURCE: how do you set the
Press and hold the % button, till it says TAX in the display. Type in the rate (currently 15% in the UK) then press % button again. Rate should now be set.
HTH
Jayne
SOURCE: Set Tax Rate
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
