Repaired two fuel lines ,removed sending unit from tank, can't remember which lines go where three lines from engine .
Can you identify or remember which pipe on the sending unit, the pump module, is the main outlet from the pump?
The three lines are the main feed or pressure line to the engine, the return line from the engine to the tank-this line is often smaller than the main line. And the third line is not a fuel line, but the vent line for fumes from the enclosed tank to the charcoal canister. This line may be identifiable by pipe diameter being smaller, or sometimes using rubber hoses with it, or maybe just a little offstanding from the other two lines. The main line (pressure line) will be the line that has the fuel filter in it. You can identify the main line this way, then just figure out where it connects onto the tank, and sort out the other two lines-the return line and the (?smaller?) vent line.
