Question about HP LaserJet 2840 All-In-One Printer
Scanner 5 Error Printer in shop but unable to get new parts
My printer and HP2840 Color Laser Jet has been in a shop since February 2009. I've been told by HP and this shop that only a new Scanner Assembly will solve the problem. But now we can't get a Scanner Assembly. I had just loaded this printer with over $500. worth of toner and I want my printer back. It is ludicrous that I can't get the part to fix this printer. If I can't get a part and my printer back I will never buy another HP product as long as I live. I'm pretty disgusted by this.
    Problem Solver:
  • 6 Answers
You are right you do need a scanner assy as they do go bad. I am sure they are available however, as the 2840 is a popular model. Try Google, partsnow.com and other parts stores. Finding a tech to do the repair will be your next challenge, but it is not a tough job.
Posted on Oct 08, 2009
  • 3 Answers
The solutions for this are posted elsewhere on this site, look for "Scanner Error 5". Basically, it's one of several things that can be cleaned or adjusted without having to replace the entire scanner head. If it does need parts they should return the printer to you until the parts are available. This error does not prevent you from printing. Even though the printer shows the error message and tells you to cycle the power, you don't need to. It will still print with this error. Find a repair shop with someone who knows what they are doing, or get a #10 Torx screw driver and fix it yourself.
Read the other thread. Could be dirty mirrors, dirty or crooked film sensor strip, or bad light bulb, all of which can be easily repaired.
Posted on Jul 25, 2009
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
How to solve the hp laser jet 52 scanner error
there are three usual faults that cause this
1. the scanner is unable to locate home position- remove the scan glass/ clean and lubricate all rails
2. the ribbon cable has open circuit on tracks- replace the ribbon cable connecting the scanner to printer
3. the printer main PCA has failed and cannot control the scanner- replace main PCA
Dec 17, 2013 | HP LaserJet 3055 All-In-One Printer
Hp error 51.21
Here's what your error means : A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Dec 24, 2012 | HP COLOR LASERJET CP 3505 N PRINTER
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
Jul 12, 2011 | HP LaserJet 3052 All-In-One Printer
HP Color LaserJet 2605dn_2605dtn error code 51.22
The 51.xx error occurs when there is an error in connection with the laser, if you open the printer to clean the lens, surely you have forgotten to replace the cable connection purple laser. open it again and reconnect all cables OR: 51.X PRINTER ERROR A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Mar 06, 2010 | HP LaserJet 2605DTN Color Printer
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
Scanner error
You will have to replace the scanner assembly.
HP Part # C9124-60103
This replacement shoult take 20 minutes.
Jan 01, 2009 | HP LaserJet 3330 All-In-One Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 All-In-One Printer Logo
318 people viewed this question
Seeker5211
Seeker5211
