Question about Microsoft Xbox 360 Console
Same problem! i'm trying to fix it right now. its driving me f***ing crazy!
  • 48 Answers
Xbox v ps3 = ps3
Posted on Jul 23, 2009
1997buick park ave won't stop d inging when driving oil light flashes...check oil and it has oil...driving me crazy
Hello Robert, you could have a bad oil sender unit. Install an auxiliary oil pressure gauge to measure the amount of oil pressure. If reading is around 15 PSI or better at idle, change the oil sender unit.
Apr 05, 2015 | Cars & Trucks
I have a Whirlpool Gold bottom freezer refrigerator. A couple weeks ago it starting buzzing very loudly when the motor is running. The back is enclosed but I vacuumed underneath. It seems to be work
Is the sound coming from inside the appliance? If so, there are two possibilities. An item in the fridge (bottles are the usual culprits) could be resting against a surface that vibrates during operation. Or it's a problem with your circulation fan: it is either hitting something when it spins or has a bad bearing and needs replacement.
If the sound is coming from under/behind the box, your compressor is banging against something or it is on its way out.
Oct 07, 2014 | Refrigerators
How do u unlock your steering wheel and ingnition for a 99 sunfire gt
Place ing key in ingtion make sure u r in park or clutch if a stick shift is pushed all the way to the floor, then grab stering wheel tight turn wheel to left and hold while turning ing key, or try turning wheel to right while trying ing key, steering wheel can lock with pressure causing ing key to be non turnable same with transmision, park or clutch to the floor. Hope this helps
Mar 05, 2012 | 1999 Pontiac Sunfire
The guages on my F350 super duty go crazy while driving
Two possible fixes : 1. Replacing the GEM module. 2. Check the electrical connections including wires.
Jun 01, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
I have a 96 grand cherokee laredo 6 cyl. Is
you should probably take it back to him and make him fix it right. sounds like there is still a problem there
Nov 17, 2009 | 1999 Jeep Cherokee
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Missing, spiting and stalling when the car warms up.
One think you can check right off is for any cracks in any vacuum lines or holes in vacuum operated valves if they exist in that model year. Just a thought.
Dec 26, 2008 | 1995 Pontiac Firebird
I can`t see the harddrive from my PC
Try looking for the drive in the "Disk Management".
Right click on "My Computer" or "Computer" and select "Manage" then select the "Disk Management" item.
If you can see the drive, but there is no drive letter assigned, you may need to format it for your operating system or create an accessible partition on the drive. You can access all these options by right clicking on the drive from the "disk management" screen that you should be on.
mine needed to be initialized (by right clicking on it) and then i formated it
Good Luck!
Oct 26, 2008 | Buffalo Technology 250GB MINISTATION TURBO...
How do I create folders?
Under WinXP Pro the MP020 shows up as 'Panasonic Audio Player' with a folder 'Fixed Storage'. Try to do File>New Folder on the 'FIxed Storage' and no can do.
Build a new folder under you C: drive.
Go back and clip on 'Fixed Storage'. I see a file WMPinfo.xml.
Go back to the folder you just built under C: and click/drag to the right.
The new folder should be under the 'Fixed Storage' folder.
The new folder under 'Fixed Storage' has a bot more functionality associated.
I'm not crazy about having to do it this way but it works.
Now someone tell me how to speed up the transfer process
Mar 01, 2008 | Panasonic SV-MP020 MP3 Player
Microsoft Xbox 360 Console Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
