Question about Bose Lifestyle 8 series II System
Bose Lifestyle 8 no display
I have a Bose Lifestyle 8 and though the system works fine, the display has suddenly stopped lighting up. Thought it might just be a loose cable or something, but doesnt seem to be. Have shut system down, turned off, turned back on...still nothing (for months now). Any help appreciated. Thanks
  • rbenoit Dec 27, 2008
    No display on Bose Lifestyle 8
I had the same problem and Mark Burgess at http://forum.ecoustics.com/bbs/messages/1/125990.htm helped me out, change the 4 capacitors in the lower board, lower left side and that will solve the issue.
regards
-Luis Carballo
Posted on Jan 15, 2008
Bose lifestyle plays for 5min shuts down
Do the easy troubleshooting first! Get a source of clean, dry compressed air and blow out the inside works. Next, get some contact spray and spray into the volume control potentiometer and work it down and up.
Jan 13, 2013 | Bose Lifestyle 8 series II System
Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Mar 31, 2010 | Bose Lifestyle 28 System
No display lights on bose lifestyle 8 home theatre. System works though.
Displays die quite often on receivers just one of those things that happens.
Bose is pretty good about repair cost and timely in their turnaround. Here is a link to the support page
I would guess a replacement display would run about $150 installed plus you will have to ship your unit to them.
They like to do "flat rate" service plans which is one of those 50/50 deals most of the time you are better off just paying for the repair versus dealing with a service contract but you will have to find out whats available for your model.
Hope that helps
Feb 12, 2010 | Bose Lifestyle 8 series II System
I have the same problem, display does not work. Suddenly its gone.
well is hardware problem. send to repair.
I know these, because i was BOSE Tech. nothing you can do now, send to BOSE repair center.
Jan 03, 2010 | Bose Lifestyle 12 System
Bose Lifestyle System 12-no lights in display-TV sound doesn't wo
There is a service available at www.AnyoneCanFixIt.com where you can send it to fix the display. Quick service and way cheaper than Bose.
Apr 01, 2009 | Bose Lifestyle 12 System
Sound just stopped
You need to replace the audio amplifier IC´s because maybe are damaged
Nov 17, 2008 | Bose Lifestyle 48 System
Bose Lifestyle V20 - no video out, no response to remote control
check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Oct 05, 2008 | Bose Lifestyle V20 System - black Theater...
System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Aug 16, 2007 | Bose Lifestyle 12 System
Bose Lifestyle 8 series II System Logo
661 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
