SOURCE: we had a power blackout now my panasonic genius
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven.
On the "Timer/Clock: button:
4 taps ON The oven is in Demo mode.
4 more taps OFF The oven is not in Demo mode.
SOURCE: How do I get my
Hello
Two options to try:
a) Press the Clock / Timer button 3 times
b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
SOURCE: Panasonic Microwave Dimension 4 convection (11 yrs old)
You need to press clock 3 times, then start 3 times and then clear/reset 3 times. Then you can reset the clock by pressing clock 1 change the time and press clock again.
SOURCE: My Daughter set my Panasonic
Once your Panasonic microwave is in Demo mode, the unit won't be able to be operated. You need to deactivate the Demo mode to be able to use the Panasonic microwave again.
To deactivate the Demo mode, press clock button on the control panel three times. This will deactivate the demo mode.
The moment the Demo mode has be deactivated, the display panel of your Panasonic microwave will go blank. This means you have successfully turned off the demo mode.
I hope the above helps.
Good luck.
