Question about Plumbing
We live in a slab home. We have been noticing a order that smells like sewage. It is mainly coming from the floor heating vents in the kitchen and in the back laundry room. Is there a way to find out what is making the smell. We sprayed the vents out with a bleach and water solution but then smell came back in a couple of days.
  • JOHN SCHWEIGER May 11, 2010
    I am not Quite sure when you say Floor Heating vents I am not sure what country you live in but if you have Floor vents like Floor drainage in bathrooms and Laundry You may have A water trap underneath the Drains ( aprox 2inches to 4 inches in Diameter )they are meant to take any overflow and spillage away In the water " S "Traps there should be some water when this water seal breaks or dries out you do get a sewerage smell Just top them up with water,Poor a small amount of water into them and that should rectify your Problem
  • 297 Answers
Some where under your slab your sewer pipe has broken. most times you must cut away the concrete floor and explore for damaged pipes.
Posted on Jul 24, 2009
Rotten egg smell/sewage smell in restaurant
check for dead rodents in the ceiling. Have a plumber check for blocked /leaking drains especially around the dish washer drains . If you have had pest exterminators in lately then something may have taken the bait . IT will be best to get in professionals to remove the smell as quickly as possible as to customers a smelly restaurant is equal to bad hygiene and food poisoning.
Feb 20, 2014 | Home
Smell of sewer in the house
Ensure all your additional rough in plumbing is capped, and toilets or sinks that are not used for long periods of time , sometimes p traps may dry up allowing sewer gasses to enter the home so use them once in a while or fill with water once in a while ,same with floor drains. If that isn't it check that you have them installed.
Jan 06, 2014 | Northstar Sewer And Drain Cleaning...
The right type of vent for a moble home
Some vents are adjustable where as you can turn them at the angle you want get those if you can,the vents dont have to be for mobile homes only. Take one of your older vents to an air conditioner parts store they should be able to match one for you.
Nov 13, 2013 | Heating & Cooling
When the toilet is flushed, there is a sewage smell.
Most likely you have an uncapped sewage vent inside your house somewhere. if this is the case all you have to do is locate the vent and cap it, or vent it outside.
Aug 21, 2011 | Home
My water heater runs constantly lately and i noticed water at my property line and around half my house. i can't tell where the leak is coming from. house is on slab. i am afraid to ask. the floor...
Does the hot-water line running from the heater go into / under the slab before going back into the house?
Or does the pressure relief valve drain line on the water heater go into / under the slab ?
It could be as simple as a faulty pressure relief valve on the heater (which would be the most likely of the two possibilities). When the water heats, the pressure builds in the tank, the water flows out the faulty pressure relief valve and down the drain line under the slab.
A plumber would be the person to call.
Charlie
Feb 19, 2011 | Kitchen Ranges
I was using the "dry" cycle and noticed the dryer stopped after 10 minutes. When I opened the door, very light smoky/steamy stuff was coming out the door and there was a slight burning smell. Now, it...
here are two sites, i would say the vent is clogged and that the thermo switch on the motor tripped but I am not an expert, just cheap charlie:
http://www.home-appliance-kitchen-aids.com/dryer-repair.html
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
I prefer the last site, but that's just me. hope this helps Tim
Oct 17, 2010 | Asko T780 Dryer
About 5 days ago I noticed a strong chemical smell (like open permanent markers or nail polish remover) in my kitchen. The smell permiates the whole house, but is strongest in the kitchen area when I close...
No. The coolant cannot leak as a liquid and soak into the floor. Also, the smell of the coolant (refrigerant) does not have the acetone/ketone/laquer thinner smell that you are describing, and if someway the smell originated from the frig, the smell would without a doubt be inside the frig as well. You need to look frosome container stored in a cabinet or stored on conrete floor that has rusted or opened some way and the thinner/cleaner/solvent has leaked from such a containerwithout notice. Goodluck, Macgivor
Jan 27, 2010 | KitchenAid Superba KSCS23IN Side by Side...
Smell when drains
THE VENT IS BLOCKED ON THE HOUSE DRAIN MAKING THE SMELL SURGE OUT OF THE PIPE WHEN THE PUMP STARTS PUMPING THE WATER OUT, CLEAR THE DRAIN AND VENT, SOME HAVE TO BE DONE FROM THE ROOF OF THE HOUSE,,,
May 29, 2009 | Washing Machines
Problem running heater
Its not good that you dont know where the air filter is. Odds are there may not even be one in place. In Most mobile homes they dont pay much mind to proper filtration. The heat strips are covered with dust. If the heat Strips are that bad then usually the whole unit is clogged. Is there a unit inside the mobile home?? Or is the unit outside quite large and have ducts running to it??
Nov 24, 2007 | Heating & Cooling
Diswasher drainage in an island
Dbootin,
I suggest just putting a dedicated Drain in the island next to the Dishwasher. You can hide it in side the island. Under the house, tee into the Main Sewage drain.  You should not need to vent it as the sinks vent is near enough to keep you from worrying about that.
Oct 31, 2007 | GE 24 in. GSD4000J Built-in Dishwasher
Plumbing Logo
140 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
