Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer 451K125, bobbin case is stuck in place - I pulled on the bobbin case latch to release it but it won't come out. Followed instructions to get needle at top position, can see some thread hanging about. I'm new to sewing machines and wish to understand how it works, plus do some sewing. Help please!
  • richard_kan Aug 26, 2009
    Thanks. I've turned it forwards and backwards - it won't come out. I took it to a shop and they believe they may damage it if they force it out. They also consider it beyond economic repair (or don't have confidence to tackle it). Looks like I'll have to strip it myself and make it work! Do you know of a good service manual?
  • 136 Answers
Try turning the hand wheel backwards
Posted on Aug 26, 2009
  • sewtexas Aug 27, 2009
    Service manuals are not usually available to the consumer. Worst case senario is replace the hook and bobbin case
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
How do I get the empty bobbin out of bobbin case. Singer sewing machine
Most bobbin cases have a release latch that allows the bobbin to drop out of the bobbin case. In the following link, it is the flat lever with the hole in the center that extends across the entire width of the bobbin case--it just lifts up. The other projection is the finger.
Singer Bobbin Case
Mar 11, 2017 | Singer Sewing Machines
Singer 306w bobbin case handle has broke off & can not get it out of the machine. Please help!
Try to remove the hook assembly. The handle on the bobbin case is also part of the latch. Using a large needle to release the latch may work.
Dec 26, 2016 | Singer Sewing Machines
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
Why the bobbin casing won't snap into place
Usually you need to hold the little latch open until the bobbin case is seated in the machine. Perhaps this video will help;
Singer Promise 1408 Get started
Mar 29, 2016 | Singer Promise 1408 Sewing/Quilting...
Bobbin case wont stay in place when I sew
Most bobbin cases have a latch that must be released to remove or install in the machine. Be sure to hold the latch open while you insert the bobbin case into the machine. Rotate the bobbin case slightly until it feels seated. Then release the latch. If the bobbin case is not latched in place, it will continue to fall out whenever you begin to sew.
Apr 01, 2015 | Sewing Machines
Singer 5528...help please!
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 5528) & click search
and it will bring up the manuals that are available
try checking the bobbin case for burrs & make sure the the small bar on the bobbin case is not bent
make sure the bobbin case is in correctly
Feb 03, 2012 | Singer Sewing Machines
I can't get the bobbin case to stay in
are you sure that the bobbin in the case is the right one for the machine firstly, and also that it is in the right way? Then check that it has gone into the rotary hook correctly, there is usually a latch you use on the bobbin case to lock it into place, like a little flap you pull out, put it into place, then release the flap so it locks in.
If you don't have a manual for your machine that details the above then you can download one from the singer website. http://www.singerco.com/accessories/instruction-manuals, type in the model number only and click on "search", wait for the screen to build and you should see your model with an icon beside it "Free Download", click this and again wait, its a large pdf file so will take some time to download to screen. Once you see it, click on the Clipboard icon to save it and browse to a local folder where you want to save the file. You can then view it when you need it or print it out to bind and keep with the machine.
Aug 22, 2011 | SINGER 7470 Sewing Machine
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Dec 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
209 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
