Question about Home & Lifestyle Software
Macromedia projector has stopped
I just installed a new game on a new computer. Every time I try to load the game I get an error message that says macromedia projector has stopped, program will close now.
How do I fix this?
  • 58 Answers
Re: Macromedia projector has stopped
You might try reinstalling Macromedia Projector (now Adobe Flash).
Sometimes if you use compatibility mode to run the game:
  • Click - Start, Programs, Accessories, Program Compatibility Wizard.
  • Follow the prompts to set up the compatibility mode.
  • Use Windows 98 compatibility, and disable visual themes.
Also you could change Apple Quicktime to run video in Safemode:
Quicktime Player > Edit > Quicktime Preferences > Advanced > and under Video Change from DirectX to Safe Mode (GDI)
You may need to reinstall Quicktime, but uninstall the old version first.
Posted on Nov 21, 2007
0 characters
3 Points
Having installed Serif Platinum on my old computer am now trying to install this on my new computer Windows 7 instead of XP and am getting an error message 230383 can anyone help please Kathleen
This probably popped up because Windows 7 can't handle alot of old programs without compactibility mode. Go to the installation .exe, click with your right mouse button on it, select properties, go to the tab "Compactibility", enable it, and select XP in the list.
Apr 10, 2011 | Singer Home & Lifestyle Software
Will not install
unfortunately, your computer is only 16 bit and will not load the program you are trying to load which requires a 64bit computer. two solutions. 1. get a larger bit computer or a lower level program which only requires 16bt or below.
Jul 27, 2010 | Cosmi Family Tree Maker
Program shuts down when starting if for the 2nd time.
The game must have been corrupted.
The only way is to uninstall it then reinstall it again.
Also make sure that your pc meets the system requirements to run the game. Free up your disk space too, before you reinstall the game.
Jan 02, 2010 | Dell Mickey Mouse Preschool (Ages 2-4)
I bought a new hp touchsmart computer, and i get
If you using operative system above Windows xp, it is not compatible. Se here :
They write compatible with : Windows Me / XP / 98 / 2000
you can try to upgrade your software to a newer version, try to ask the software provider, normally it is writed in the field About under the Help menu.
Hope that helps
Have a nice time over there
Please rate my answer
Nov 28, 2009 | Broderbund American Greetings Spiritual...
After downloading a game for my son onto his computer he recieved a message that the application crashed. What does this mean? How is it fixed? He is quite upset and I don't know what to do
mostlly this happens when you downloaded a corrupt file, anyway let see if we can fix it using the restore mode, if you're already familiar with it try to restore it using the date before the game was installed if not follow these instruction.
1. upon bootup press "F8" and wait for the option that lets you select some option such as safe mode, safemode with networking, etc, etc,
2. select the "safe mode", your pc will load with only minimal option a popup box will appear asking if you're going to use restore mode. (if your pc crashes before it loads the system stop rigth here, your system needs to be reformat, otherwise pls proceed)
3. click "START", "Program", "Accessories", "System Tools", and then "System restore"
4.popup box will appear select ok or continue until you reach the calendar option that will let you select the date you want to restore in an earlier time, pls select the date before you install the game ex. you install the game on 10/15/09, then select the 10/14/09 or later then select ok or continue until it reaches finish.
5. reboot the pc, this should solve your problem
Oct 15, 2009 | Home & Lifestyle Software
My GTA SAN ANDREAS gta_sa.exe has stopped working
you have installed mods: when are you installing mods, you are installing hidden files too. With too much hidden files, the game crashed. there is only one way to delete this hidden files so you can play gta sa again is reinstall windows. then you have no problems.
you have installed no mods: I don't know how to solve this. maby you can try to do this: Click start>Right click "my computer">Properties>Advanced> Under performance hit 'settings'>Data execution Prevention> hit "turn on DEP for all programs and services except those I select".
Hit Add, browse to your cracked .exe in the SA folder. Hit Apply. You should have to restart.
Now GTA should run.
Jul 07, 2009 | Home & Lifestyle Software
The sims 3 won't start
Hi, please tell me the error message you get for furthur assistance.
Jun 12, 2009 | Microsoft Home & Lifestyle Software
I am trying to install the PC game The Moment of Silence
make sure the disk has no scratches also make sure that ur computer meets the requirements of this game. usualy when it dosent it will not install
Jun 05, 2009 | Home & Lifestyle Software
Data Becker Music CD Recorder 3.0 won't run on my new computer
If you are using Vista it won't run on it. I am having the same problem and looking for an update of it. I have used it on XP with no problem.
Mar 01, 2008 | Home & Lifestyle Software
Home & Lifestyle Software Logo
666 people viewed this question
Top Home & Lifestyle Software Experts
john smith
Are you a Home and Lifestyle Software Expert? Answer questions, earn points and help others
