Question about Dometic RM2193 Compact Refrigerator With Ice Box
3 way small frig no power noted
I have a 3 way small frig in a 1993 Jayco pop up have not been able to get frig to do anything where do i start troubleshooting it
    President:
  • 704 Answers
Here's a link to the owners manual with all the instructions for operating the fridge on gas, 120V-AC, or 12V-DC.
The key with this popular fridge is to be sure the control switches are in the correct position for the power source you want to run it on, as it will not work on gas if the electric switch is on, and vice versa. Also note that you can only use one (1) power source at a time to run the fridge.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Print out a copy for your use and save an electronic one in case you lose your printout. Hope this helps you get the fridge up and running!
Posted on Jul 30, 2009
I need a wiring diagram for trailer plug on 1998 jayco hawk pop up
you can get that from any jayco caravan retailer
they wire plugs as per the standard diagram hat you get with and plug from any auto parts shop
Jul 06, 2017 | Cars & Trucks
What is the height from level ground to the bottom of the bed on a 1997 Jayco pop-up
The instructions for it are here. There is a technical drawing of it that you can use by measuring the size of a known item like the tires. There is also the contact details so you could ask Jayco.
Surely, you get in the trailer and then the bed is a standard distance off the floor. Bed and braces are shown on page 31.
http://www.popupportal.com/manuals/Jayco/Jayco_1997_Jayco_Camping_Trailers.pdf
Mar 24, 2017 | Cars & Trucks
Help please with a jayco pop top caravan its I/d as far as I can see is 109502
take it to a jayco caravan center and have it explained to you
they may even be able to supply you with a schematic diagram
Nov 05, 2016 | Cars & Trucks
Where are the fuse boxes located in the jayco freedom pop top, 2000 model please, we have searched and are unable to locate it
If it's the 120 volt panel you're looking for, follow the power cord into the unit. If it's the 12 volt side, these should be near or behind the 120 v panel.
However, that's not always the case with Jayco. Often the power cord comes in at the rear and the panel is in the middle of the unit. In some models it's in back of the plywood panel under the refer.
Some appliances (such as a refer) have their own fuse located on the control panel.
If you contact Jayco they will send by email the owners manual for your model and year. Here's where to contact them at:
Contact Customer Service Jayco Inc
Jan 03, 2015 | Cars & Trucks
De-winterizing RV (2011 Jayco 29 QBH) when hit the battery pump switch, water shoots out city water connection.
Remove the screen/washer at the city valve and you see a small stem in center of valve, that's the plunger (check valve ) . Use a pair of needle-nose pliers if necessary to push it in ( it should have spring behind it) slightly and make sure it is centered in the hole, then just pull on it slightly to seat it. Now try pump. If it won't seat properly and water still shoots out, it's probably defective and needs changing. Perhaps whoever winterized it forgot to push that in after pumping antifreeze through system, which results in water trapped in valve, thus freezes and breaks apart inside. If your stuck, screw a plug the right size into the city water fitting. Short piece of old garden hose with male end & plug (old bolt or anything proper diameter) and small hose clamp in other end will work for temporary use even.
Apr 18, 2014 | Jayco Jay Flight 29 QBH RVs
Broken Cable on Pop-up trailer need help
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Sep 06, 2009 | Sport & Outdoor - Others
Used 1981 Jayco pop-up travel trailer
Are these the bunk supports. I have a jayco of my own and I know there are lots of slots to put thinhs in so it can be difficult but each model is slightly different and if one support isn't in right than this can damage the frame. I would go to the jayco site and search for the nearest dealer and they are always helpful. But the nearest dealer might be a little ways away as alot of them are going out of business or merging with other dealers. The website is : http://www.jayco.com/php/products/camping.trailers/camping.trailers.php
Sep 24, 2008 | Sport & Outdoor - Others
Refrigerators not cooling
no reset but the frigs do have overload circuit that will shut compressor down,the frigs. compressors need a certain about of amps to start and to run ,what is the amp rating on your generator?let me know-mike
Sep 22, 2008 | Refrigerators
Jayco pop up repair manual
I have the original schematic for the pop-up cable system on my Jayco. what year is your Jayco?
Oct 29, 2007 | Computers & Internet
Dometic RM2193 Compact Refrigerator With Ice Box Logo
573 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
