Question about Sharp AL-1642CS Copier
Continue warmup sound, even copier is redy for use
Sir
i have sharp copier ARM420U and its giving continue warmup sound even manhine is ready to use.
therefore, i am requesting help from you.
    President:
  • Sharp Master
  • 990 Answers
Hello sir;Would you let the machine running until it stop( it will stop) if after it stop with the red triangle simple show out the mean the machine toner motor defect, please let me know the resolve.
Posted on Jul 23, 2009
Sharp arm420u shows replace toner cartridge frequently in new cartridge also
I would check the connector on the rear frame for the toner cartridge, it is easily bent when cartridge is forced in and is maybe not making good connection
Jul 25, 2012 | Office Equipment & Supplies
What do the flashing light mean on a lexmark E260D. please help
We would like to know more about the flashing lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information which light is flashing on the printer.
For further assistance, please call Lexmark Technical Support.
Jun 24, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
My copier is Sharp ARM420u it displays E7 call for service how do i solve this problem?
E7 01 Duplex model memory error/ Image data error
02 LSU trouble
06 Image data decode error
10 Shading trouble (Black correction)
11 Shading trouble (White correction)
16 Abnormal laser output
Jan 04, 2011 | Sharp AR-5320 Black and White Copier
I Have Sharp Photo Copier AR 5316 when i given Print command the image was good but background double image was also come pls sir give some urgent tips sir
Needs a fuser hot roll. Once the get worn, they pick up some of the image and reprint it on the page.
They are available form several sources, Kaytin comes to mind. Precision roller. Google the printer model number . I would google is like this. Sharp AR 5316 hot roll.
That should give you several sources, Honestly I would replace the press roll also. Probably you should be able to find them both for less than 100 dollars, I sure wouldnt pay more. Look around. You can find them for a decent price. You may even want to look on E-bay. they often have them there.
Aug 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Continued cycling but will not copy
Hello sir; the copier it will stop, give them more time, if it stop with a triangle light on that's means you need a toner motor to replace.
Apr 23, 2009 | Sharp AL-1642CS Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Emission rediness codes on after repair & clear
unhook the battery for about ten minutes... make sure you have the code for the radio (if required)
Feb 26, 2009 | 2001 Dodge Dakota
Sharp AL-1217
It sounds like its either the wrong cartridge or the actual crum chip on the cartridge is faulty
Mar 14, 2008 | Sharp AL-1217 Copier
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
