Question about SanDisk Sansa Clip MP3 Player
It`s has conflicts with windows
When i plugged in the USB port windows detects it but it has conflicts!!! I must download a driver for this??
  • 805 Answers
U can search driver in google page and download from it then try. thanks
Posted on Jul 23, 2009
  • 144 Answers
Install service pack 3 if using windows xp becuse the driver is built in or try updating the firmware on the player
MY TRANSCEND PENDRIVE NOT WORKING
Possible solutions:
*See if the USB port is enabled in bios.
*Goto Run> Services> Plug and play > Properties(Right Click)> See if it is set 'Automatic'.
*Try disabling USB2 in your bios, restart your operative system, and if still not detected your pen drive, try making OS detect new hardware or hardware changes (to crange usb2 drivers to usb1 drivers).
*If the above steps don't work for you, it might be a driver conflict. Try installing the Transcend USB driver from the manufacturer site, and see if that works for you.(Check in Device Manager, If there is a conflict after installing the new driver : Rollback Driver).
Please let me know the feedback on this.
Jan 11, 2011 | Computers & Internet
How to instal a webcam without a cd
You can plug it into a usb port, and usually windows will detect it and install it with its built-in drivers.
Otherwise you can try to download a driver from the net, and try that.
Once in awhile, there might be a conflict, but most of the time it will work.
Good luck, and hope this helps.
Dec 21, 2010 | Computers & Internet
XP crashed on my Dell latitude D600 laptop. I
go to mfg websight and down load all th proper drivers there is likely a mother board driver not installed that allows it to see the ports
install all of the manufacturer's drivers
dont expect that microsoft wrote windows just for your computer it is a general set of generic drivers that make most things work but not every thing
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
Aug 03, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
USB Device Not Recognized
try downloading the drivers from sony first http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C116935&fes=true&mdl=DSCW5 that is if you have already downloaded the proper usb drivers for your system in which case other usb device are still working also it is possible that the usb port itself has gone bad or is in conflict with another driver assuming your using windows to check this you can start by telling me which version of windows you are using but more than likely the proper camera drivers will solve the issue
Apr 26, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Onboard usb
VIA needs to stop making USB chipsets... lol... Are you sure you have USB legacy support enabled? Moreover, the default Windows XP drivers are not error free when used with a VIA Rev 5 USB Host Controller because it's actually a VIA Enhanced Host Controller. Every time I have USB problems with the VIA Enhanced Host Controller I go to there website, download the driver, and it usually fixes the problem.
USB 2.0 (VT6202, VT6212, VT6214/L)
Moreover, I have plugged in a Microsoft Wireless Optical Mouse and Windows XP could not detect it until I installed Microsoft Intellipoint; if you can believe that. Try also installing the mouse drivers as well...
Nov 27, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
When I plug in my Zen Micro to the PC to chage all i get is the flashing charge signal but the devices does not recgharge. This is the same USB that i have used successfully on another PC. it also wont...
I use to have that little player and i remember how it could be tricky on different computers.
from http://www.anythingbutipod.com/forum/showthread.php?t=27711
If these don't work please report back:
4. If the Zen is not detected by or charging from the computer when connected, make sure you are using a USB port on the back of the computer (built into the motherboard) instead of one wired to the case (front or side). That way you are using a USB port with the proper power output.
5. If the Zen is not detected by or charging from the computer when connected, make sure the USB port you are using are USB 2.0 and not v1.1. If you computer is a newer computer, this shouldn't be a problem, but if it is an older computer, it may only have USB 1.1 ports which doesn't output enough power as USB 2.0 ports.
6. If the Zen is not detected by or charging from the computer when connected, make sure you have no other USB devices plugged into the computer (front and back ports), but the Zen. That may be worth a try to see if you can get enough current from the USB ports to begin charging it again. Usually the more devices you have plugged into the USB ports, the less current that will be available for charging due to the power being shared with all other devices plugged in.
7. If the Zen is not detected by or charging from the computer when connected, make sure that the drivers are loading for it properly under Device Manager (no conflicts showing). I believe the Zen will not be detected or begin charging unless its drivers are loaded and working properly.
Jul 30, 2008 | Audio Players & Recorders
HI HAVE PROBLEM MY HP PHOTOSMART C4280 I TRY TO SCA AND TELL ME NO USB PLEASE HELP
You can try making sure the cord is securly attached on both sides, and make sure the computer is recognizing the (assuming)scanner or all in 1. You might also want to try reinstalling the driver for the printer.
Jul 18, 2008 | Office Equipment & Supplies
Computer (XP SP2) doesnt detect camera
Go to your computer's administrative tools and find services. Check the status your camera software. Status should read automatic. I had a software conflict that turned my camera window off.
Oct 07, 2007 | Canon PowerShot A550 Digital Camera
SanDisk Sansa Clip MP3 Player Logo
214 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
