Question about HP Officejet 5610 All-In-One InkJet Printer
No Scan Options
When i click on the options scan it says that no scan options
  • IT Solution
    IT Solution May 11, 2010
    u can reinstall software ur hp scanner.
    President:
  • HP Master
  • 1,447 Answers
It is the problem your scaner driver please install it properly then you can scane it
Posted on Jul 23, 2009
How to scan documents
  1. Position the document on your scanner.
  2. On the File menu, click Scan New Document.
  3. In the Scan New Document dialog box, select the options you want.
    • To select additional scanning options, click Preset options, and then click either Create new preset or Edit selected preset.
    • If you want to scan a double-sided page, select the Original is double sided check box.
  4. Click Scan.
If you selected the Original is double sided check box, the Scan New Document dialog box reappears as necessary.
  1. If you selected the Original is double sided check box or the Prompt for additional pages check box, click Done to save the file after the last page is scanned.
Feb 17, 2011 | Cycling
Had been scanning pictures into computer and now i
First let us remove the No Scan Option.
First try to Scan from HP director or HP Solution Center.
If it is scanning, perform the steps given below to resolve the issue.
Open HP solution center/HP Director:
Click on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
Jun 02, 2010 | HP Photosmart 3210 All-In-One InkJet...
How to Scan to PC Photosmart C4599
open solution center click settings then scan settings. click scan to set up then select front panel list
a new window opens up showing double pane. on left handside are options to add to the right hand pane... once those options are added click update the device. re try the scan from the printer.
Apr 06, 2010 | HP Photosmart C4580 All-in-One - InkJet...
"no scan options"
" no scan options refer to device documentation for trouble shooting"
you need to open up either solution center or hp director, go to settings, scan settings, then scan to set up and look for the option front panel destination a window should open to reveal scan short cuts and one titled front panel list. you need to select the shortcuts click add and once satisfied click on "update device".
Mar 27, 2010 | HP Photosmart C6280 Printer
I cant scan to computer
  4. Click Scan.If you selected the Original is double sided check box, the Scan New Documentdialog box reappears as necessary.
  5. If you selected the Original is double sided check box or the Prompt for additional pagescheck box, click Done to save the file after the last page is scanned.
Note By default, OCR is performed automatically when you scan documents. To turn off this feature, click Scan New Document on the File menu, and then click eitherCreate new preset or Edit selected preset. On the Processing tab of the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned imagecheck box.
Hope this helps!!!
Please rate my response!!
Jan 29, 2010 | HP Photosmart C4580 All-in-One InkJet...
HOW DO YOU SCAN DOCUMENTS
  4. Click Scan.If you selected the Original is double sided check box, the Scan New Document dialog box reappears as necessary.
  5. If you selected the Original is double sided check box or the Prompt for additional pages check box, click Done to save the file after the last page is scanned.
Hope this helps!!!
Jan 29, 2010 | Microsoft Word for PC
"no scan options error" appeared
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Jul 16, 2009 | HP Photosmart 3310 Printer
No scan options say refer to device documention to trouble shoot
Try ths:
Click on Settings
Click on Update;
Regards Soumajit
Mar 02, 2009 | HP Officejet 4315 All-in-One Printer
HP Photosmart C5280 Printer -scanning
Try ths:
Click on Settings
Click on Update;
Regards Soumajit
Jul 20, 2008 | HP Photosmart C5280 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
130 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
