Question about Boating
I just purchased a 92 Kawasaki 750ss jet ski but I cannot get it to turn on. I connected the lanyard, set the choke and turned on the gas but when I push start nothing happens, can you please help?
    Problem Solver:
  • 7 Answers
Take the positive booster cable attach it positive battery terminal (assuming the battery is good) and the other end to the positive terminal on the starter. This should make the starter turn over the engine. If the engine turns over then the problem is somewhere inbetween. If nothing happens then the starter is probably faulty. Hope this helps.
Posted on Jul 23, 2009
    Sniper:
  • 197 Answers
Inside of grey box to the left rear of engine compartment you will find the starter solenoid.Check for voltage there.On the outside of box you will see a knob that you can unscew,look under it and you will find a fuse for the starting system.Be carefull not to pull to hard on the wires.Let me know if this helps.
Posted on Nov 14, 2009
1992 kawasaki sc jet ski kill switch red button and lanyard kill switch will not shut down ski. Have to undo battery cable to get motor to stop.
The kill switch and the lanyard all do the same thing, they direct the power at the coils to earth. You have a disconnect somewhere. First place to check with a meter is right below the buttons and check that you have no continuity with the button up and continuity when the button is pressed. Then follow the wiring harness and check the connectors.
May 13, 2018 | Jet Boating
2001 Kawasaki VN 800 A Vulcan will not run without choke
Hi, Cassidy and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
97 VN800 Classic won idle off the choke Kawasaki Vulcan Forum Vulcan Forums
Will only run on choke
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
Mar 23, 2018 | 2001 kawasaki VN 800 A Vulcan
What if my 1990 Kawasaki TS650 won't start when it has a brand new battery, spark plugs, and new gas. It will turn over but won't start. Any ideas?
Is this a TS650 Jet Ski, or a Motorcycle?
Did you turn the gas on at the tank? Did you check that there is fuel at the carburettor? If you try and start it, did you remove the spark plugs and see if they are wet? Does it have an automatic choke, that is stuck?
May 03, 2015 | kawasaki Motorcycles
1995 Kawasaki ZZR 1100 only runs with the choke on
Hi, Anonymous and the usual suspects are:
http://www.zxforums.com/forums/zx-11-forum/5696-92-wont-run-without-choke.html
Bike will not run off choke KawiForums Kawasaki Motorcycle Forums
Kawasaki Ninja ZX 11 Service Manual
Kawasaki Ninja Owners Manuals
Jun 13, 2014 | 1995 kawasaki ZZR 1100
2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
Jul 25, 2012 | New Ray 112 Scale Bombardier Sea-Doo XP...
My 1994 kawasaki 750ss jet ski has very low compression in one cylinder how do I repair?
Since this is not a computer game, you might want to repost in the correct catagory.
Jun 01, 2012 | Video Game Consoles & Games
I have a 1997 750ss kawasaki jet ski that has only done about 20hrs (has been in storage for 12 years) that was running fine (with a new battery) and has suddenly stopped. It turns over fine has new plugs...
There may be water in fuel,would suggest rebuild of carb,clean and new carb kit,the diaphragm may be damaged do to age,if fuel tank hoses were clogged then more than likely trash has clogged the jets.
Feb 15, 2011 | kawasaki Z 750 Motorcycles
Boating Logo
269 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
