Question about Bakers Pride FC-616 Gas Single Oven
Pilot light still going out
I actualy have a bakers pride convection flo deck oven, model 251. The serial number is post change as per the parts list, and the pilot light seems to go out at random. I have a ceiling fan over the stove with a swamp cooler inlet above that. There is also an exhaust fan and other AC inlets around. Is it possible there is an air leak somewhere in or on the oven? any known problem areas?
Thanks for the help.
    Scholar:
  • 81 Answers
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Posted on Jul 25, 2009
I need to get 2 slates for y600 pizza ovens do you sale them.
When your looking for this part it is called the "Stone Deck"
36" X 60" for most Y600 Models. FixYa is a "help you" site not a full blown retail outlet.
This is the Y-600-(old style) manual:
http://www.bakerspride.com/pdfs/Y-600%20Parts%20List%20OLD%20STYLE%207-05.pdf
This is the Y-600 manual: http://www.bakerspride.com/pdfs/PartList/Y-600%20Parts%20List%20U6050A%208-08.pdf
This is the Y-600-DSP manual:
http://www.bakerspride.com/pdfs/Y-600%20DSP%20%20Parts%20List%20U6051A%202-07.pdf
Their website went down for maintenance as I was doing this. But their phone number is on the website. http://www.bakerspride.com/
Thier manuals list is here. Note the price list for parts is at the very bottom block top of 3rd row.
http://www.bakerspride.com/manuals.asp
Thanks for choosing FixYa.
Kelly
Sep 14, 2010 | Bakers Pride Y-600 Gas Single Oven
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
I am looking for an on/off/pilot knob for a white rodgers gas valve. Model 35C67-183. Can you help?
Please re- check the part number because this is not a valid part number of White- Rodgers. Maybe this is an OEM part that why we cant see that on our system call the manufacturer of your system they will provide you a replacement.
Nov 30, 2009 | Bakers Pride CO11-G2 Gas Double Oven
Bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
WAISTING GAS BAKERS PRIDE GAS OVEN DOESNT SHUT OFF
Hi, don't know if you received an answer, however your gas valve sounds to be bad, when turned to pilot, it should only allow gas to the pilot assy. The problem is, it has already failed to shut fully, if it still does that with it in the off position, it would still be allowing gas through it, if the pilot goes out, there is now no protection to shut itself off, get it replaced ASAP. Hope that helps, and thank you.
Sep 28, 2008 | Bakers Pride C011-E2-C Gas Double Oven
Bakers Pride FC-616 Gas Single Oven Logo
233 people viewed this question
Top Bakers Pride Ovens Experts
ashburton
Paul Carew
Dan Webster
Dan Webster
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
