Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
Cant find the fuse.
Yea i got the lil diode green lite , but the when touching the power button Nothing happens. where do i find this fuse ?
  • 202 Answers
The only fuse i know of is inside the power supply. never seen a fuse blow though. maybe powersupply is bad seen that before. it is a switch mode supply and has to have a load on it to check.
Posted on Jul 23, 2009
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
It does not want to turn on even when fully charged, i can keep pushing the on button and nothing happen at all. I can charge it up but nothing at all, even touching the screen or else nothing happen.
It sounds like a blown fuse, I have just repaired my son's ds but as I couldn't get hold of the correct fuse I used the wire out of a 1 amp glass tube type fuse and bridged the faulty fuse without removing it.
See youtube video
Good luck
http://www.youtube.com/watch?v=io5iN42q3VQ&feature=related
or for an easier but dodgy method
http://www.youtube.com/watch?v=GYWt811XNDs&feature=related
Feb 02, 2011 | Nintendo DS Lite Console
Ds lite battery wont charge i have charged it overnight but nothing the green light goes on but that is it
If the green light is turning on and the screens are staying blank it is a problem with he L2 fuse on the motherboard (located just below the power button).
This can be replaced if you are handy with a soldering iron. If not drop it to a local repair shop it can be fixed for about €20.
Aug 26, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Replaced battery for lawn tractor and nothing happens.
You probably just blew the fuse behind the ignition or the fuse link on the power to solenoid.
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
White screen and power and home buttons wont work
oh yea man that happen to me u just by a new one
May 16, 2009 | Apple iPod touch
Satellite a135-s2356 aill not boot up
a friend had same issue , i dissembled laptop and found a burnt diode chip beneath where power button sits on top cover panel there are two clips under power button , one of the clips shorted the diode , only orange power button would lit up on front edge of lower case
Apr 25, 2009 | Toshiba Satellite A135-S2356 Notebook
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
My t.v won't power up
Check your diodes on the power supply some times they blow which would shutdown the low volt. use your dig flute, than check your horizontal out put transistor in the high voltage section that may have blown or shorted..that green lite is on for your safety a part inside has gone bad and the safety devise has shut down the set(fire) start first with your low voltage transistor I bet u find it i have on many occasions my e-mail cmozie@comcast.net good luck
Sep 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
194 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
