Question about Epson LQ-2180 Dot Matrix Printer
My epson lq2180 doesn't pull front tractor - Epson LQ-2180 Dot Matrix Printer
    Problem Solver:
  • 4 Answers
Check the setting on right hand side above the nob probaly you haven't positioned on the correct place,aslo check on the gears for the tractor be aligned with the roller/mast
Posted on Sep 10, 2009
How reset printer epson lq-2180 to factory
An Epson LQ-2180 is an old dot matrix printer, it cannot be programmed like newer network printers. All it has is a panel in front where you can select a font, the pitch of the font and paper type. There is nothing to reset.
https://files.support.epson.com/pdf/lq2180/lq2180u1.pdf
Feb 19, 2017 | Epson Office Equipment & Supplies
How can reset to factory setting for epson printer lq-2180
This is an old impact printer, there is really no way to reset it because it is not "programmed" or setup the way modern printers are setup. About the only things you can do are select the font and pitch.
Feb 08, 2017 | Epson Office Equipment & Supplies
Wants to know if Epson DFX 9000 and LQ2180 printers can have network cards in them to be used as network printers?
If it is Epson DFX9000n then it has a network card however you can share the DFX 9000 without a network card through a computer as a host machine.
Aug 05, 2011 | Epson DFX-9000 Dot Matrix Printer
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
LQ-2180 hasil print putus-putus & ketika sedang print bisa berhenti sendiri, apa solusinya bosss..??
TOLONG,,, BAGAIMANA CARA MENGATASI PRINTER EPSON LQ2180 YG HASILNYA PUTUS-PUTUS DAN BURAM,,MOHON BANTUANNYA
Dec 25, 2009 | Epson LQ 2170 Matrix Printer
The pause light on my lq2180 is permanently on
Check the paper sensors in the paper path, and the printhead home sensor. Paper path sensors (one or more) will be present somewhere around the platen & tractor feed areas. Printhead home will be over on the left side in the printhead movement area.
Logic board defects could likely cause this same issue, diagnosis here could be more difficult.
Nov 19, 2008 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
145 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
