ok i have a 1998 durango with the 5.2L 318 engine. had trouble with a bad cell in my battery. I went out bought an optima red top battery for it 800cca. put it in and had same trouble. No start without putting foot on gas. wouldn't stay running without holding foot on gas. CPU has to relearn it's programming once you unplug it for long periods of time. mine was without power for about 2-3 weeks till i got new battery. Start with this.. first check under air filter make sure a squirrel hasn't made a mess under your air filter and it's clogging the air intake. Then pull off the lid to your injector cover ( the screw down lid coming from the air box ( with air filter in it) to "carb") make sure all your cables move freely. put that all back together and close hood. Start truck with foot slightly on gas pedal to get started. keep it at about 1k to 1500 rpm for about 1-2 minutes. Rev motor to about 2500rpm and let it die out if it will. Get out lock doors with key fob if you have it. if not make sure to lock doors. ( trust me it worked for me) let sit for 5 minutes. come back out and unlock door and relock door 3 times with fob ( if you have it ) or key if you don't have a fob. Then unlock it with the key and enter vehicle. Start truck as before and keep it around 1k to 1500 rpm again for about 30 seconds rev it up and should keep running. Mine did. I think the iac was stuck from sitting and has now since loosened up. Good luck hope ti works for you.
when key on and engine off, does the security light flash constantly? if so its shutting down the fuel pump, it starts momentarily due to the computer priming the engine with fuel. how to reset, turn key to run position, leave it on touch nothing, takes 10-12 minutes, start watching light around 10 minutes. it will stop flashing... turn key off, then back on and start this will reset the security system. they are sensitive on this platform car it will happen again. good luck!
sounds like your fuel pump is going out. One thought might be that the fuel filter is causing enough resistance to over heat the pump. I would check the fule pressure to determine a free flow of fuel.
