I just prested down on the white on/off above the 35 and the beeping went off but that for me did not clear this crazy E 35 problem which seems to be a bigger problem than I thought! I haven't clear understanding yet for the E 35 but I do know that the burners on top no longer work at all and the timing of this problem is not good for me. Was a great handyman years ago before I lost both of my hands to an electrocution on the job accident three years ago. I can only look at the situation now and do not a thing about it and be majorly frustrated, I hear that if I've had it less than 5 yrs I can get it fixed at no penny out of my pocket. I need it fixed like now any help from out there in the universe. I have friends and even a son who may help a bit.
SOURCE: F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F0 & F1
EOC (Electronic Oven Control) failure
Replace Electronic Oven Control
F2
Oven too hot
Check Bake function, if OK, replace oven temperature sensor
F3
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
F4
Oven temperature sensor shorted
Replace oven temperature sensor
F5, 6, 7
F8
Lock switches
Check switches and replace if necessary
SOURCE: self-clean feature
hi .thanks for the question. f 3 on Frigidaire stoves, mean an open oven sensor. located in the oven top left corner, looks like a pen . replace the sensor. thanks the appliance doc
SOURCE: Code F7 appeared during oven use
You have/had a stuck keypad. If it happens again just push all pads at random to try and unstick it. If it gets to be a nuisance replace the keypad membrane.
SOURCE: I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
