Question about RCA TruFlat 27F520T 27" TV
Screen Problem I moved my tv to vacuum, Did not bump it or anything, and i plugged it back in and i get my screen looking like an hour glass shape... WTF this tv is not even 2years old
    President:
  • 1,348 Answers
The pincushion circuit is defective.bang the tv and see if the pix is normal,if so there is bad soldering on the main pc board. rca is known for that
Posted on Jul 23, 2009
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
Monitor picture is distorted
This is an indication your monitor is on the way to failure: You can do a "degauss' which is usually powering the monitor off and then pushing the degauss button in and holding it while powering the monitor back on.
Oct 21, 2008 | AcerView 77E 17" CRT Monitor
Stretched screen
Try the menu under setup, find convergence, it realigns the colors,, you are suposed 2 do that periodicly,, or when u move the tv,, should help you ,, ive got that same tv,,
Oct 05, 2008 | RCA P61940 61" Rear Projection Television
Printer not booting up after power lose.
Hi guys. I had the same problem, but looked at this thread. I guess mine was related to the power, because when I moved my plug from a power strip to a wall outlet, it worked fine.
Jul 16, 2008 | HP PSC 2410 All-In-One InkJet Printer
42HP66 - Cracked the Glass plasma screen
It is worthless. The glass itself is the sealed plasma display unit. once it is cracked it will not work correctly. The most expensive part of the set.
C-Dog
Feb 13, 2008 | Toshiba 42HP66 42 in. LCD Television
Tv screen has slight hourglass shape
A common fault are some of the electrolytic capacitors failing in the pin cushoning amp section, and probably in part of the scan amplifiers.
To service this will require the proper training and set-up to troubleshoot the set.
Take the set to a service center for an estimate. The cost can be at least an hour or two for the labour, and then the cost of the parts on top.
Jerry G.
Nov 06, 2007 | Sony KV-32S26 32" TV
Screen
Convergence mis-alignment issue.The solution is = replace
both convergence amp IC's. Part # STK392-110.......T.
Oct 29, 2007 | Philips 60PP9202 60" Rear Projection...
Green Solid Hour Glass
possible convergence amp ic's failed should be under $300.
Sep 05, 2007 | Toshiba 46H84 46" Rear Projection...
RCA TruFlat  27F520T 27" TV Logo
102 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
